Samsung Mythic SGH-a897 Camera Replacement
View statistics:
Past 24 Hours:
2
Past 7 Days:
14
Past 30 Days:
74
All Time:
842
Comments: 2
2 comments on steps.
Completed: 0
Favorites: 0
Time Required: No estimate
Difficulty: Moderate
Action Shots
Be an action hero! This guide needs images that better demonstrate how to perform specific actions.
Missing Details
Some of this guide's details are missing. Help users by adding tools, difficulty, or time.
Introduction
Go to step 1 ↓
This guide will instruct you on removing the camera from the Samsung Mythic SGH-a897 motherboard. To successfully remove the camera from the motherboard, the iFixit Opening Tool should be used to pry the camera and camera cable from the motherboard.
Tools
    1. Samsung Mythic SGH-a897 Camera Replacement, Battery: step 1, image 1 of 1
      • To remove the phone's back cover, slide your fingernail into the slit at the bottom of your phone.
      Ask FixBot
    2. Samsung Mythic SGH-a897 Camera Replacement: step 2, image 1 of 1
      • Place your finger on either bottom corner of the battery slot and lift to remove the battery.
      Ask FixBot
    1. Samsung Mythic SGH-a897 Camera Replacement, Rear Case: step 3, image 1 of 1
      • Using a Phillips #00 Screwdriver, remove the six 5 mm screws from the back casing of the phone.
      Ask FixBot
    2. Samsung Mythic SGH-a897 Camera Replacement: step 4, image 1 of 1
      • Using the iFixit Opening Tool, insert the tool into the seam between the back case and the rest of the phone.
      • Working along the seam, pry the back casing from the phone.
      Ask FixBot
    1. Samsung Mythic SGH-a897 Camera Replacement, Camera: step 5, image 1 of 2 Samsung Mythic SGH-a897 Camera Replacement, Camera: step 5, image 2 of 2
      • Carefully remove the camera by using the iFixit Tool to pry the camera cable from the motherboard.
      • Carefully remove the camera from the phone's motherboard.
      Ask FixBot
Morgan Yost
46 Reputation
6 Guides authored
Cal Poly, Team 17-1, Regan Spring 2013 Member of Cal Poly, Team 17-1, Regan Spring 2013
CPSU-REGAN-S13S17G1
4 Members
108 Guides authored
0 Guide Comments
Past 24 Hours: 2
Past 7 Days: 14
Past 30 Days: 74
All Time: 842
