Up to 20% off select tools
Samsung Moment Camera Replacement
View statistics:
Past 24 Hours:
4
Past 7 Days:
16
Past 30 Days:
88
All Time:
874
Comments: 0
Go to guide comments
Completed: 1
1 person has marked this guide "completed." Will you be next?
Favorites: 0
Time Required: 5 - 10 minutes
Difficulty: Difficult
Incorrect Tools
Help make this guide better by using the correct tools in images and/or text.
Needs Better Images
Better photos will improve this guide. Help out by taking, editing, or uploading new ones!
Needs More Images
A few more images would make this guide's procedures crystal clear.
Tools
  • Phillips #000 Screwdriver
    4.9
  • Spudger
    4.9
Introduction
Go to step 1 ↓
This guide will show users how to remove their phone's back cover, exposing many of the inside parts. It will then show readers how to replace a faulty camera.
    1. Samsung Moment Camera Replacement, Battery: step 1, image 1 of 1
      • Slide the back cover off the back of the phone to reveal the battery.
      Ask FixBot
    2. Samsung Moment Camera Replacement: step 2, image 1 of 2 Samsung Moment Camera Replacement: step 2, image 2 of 2
      • Place a finger in one or both of the indents by the bottom of the battery. Then pull out to remove the battery from the phone.
      Ask FixBot
    1. Samsung Moment Camera Replacement, Samsung Moment Rear Case Disassembly: step 3, image 1 of 2 Samsung Moment Camera Replacement, Samsung Moment Rear Case Disassembly: step 3, image 2 of 2
      • Identify and remove the 6 screws on the rear case of the phone.
      Ask FixBot
    2. Samsung Moment Camera Replacement: step 4, image 1 of 2 Samsung Moment Camera Replacement: step 4, image 2 of 2
      • Using a spudger, separate the rear case of the phone from the front case.
      Ask FixBot
    1. Samsung Moment Camera Replacement, Camera: step 5, image 1 of 1
      • Identify the phone's camera piece
      Ask FixBot
    2. Samsung Moment Camera Replacement: step 6, image 1 of 1
      • Use a spudger to peel back the green processing chip, exposing the wires underneath. Identify the thin golden band which connects the camera to the rest of the phone.
      Ask FixBot
    3. Samsung Moment Camera Replacement: step 7, image 1 of 1
      • Using the spudger, separate the golden band from its resting dock. It should come apart fairly easily, like undoing a bit of velcro. Once separated, the camera should slide out.
      Ask FixBot
Author
with
Steven Cooney
203 Reputation
1 Guide authored
Marist, Team 1-1, Laflen Spring 2016 Member of Marist, Team 1-1, Laflen Spring 2016
MARS-LAFLEN-S16S1G1
4 Members
36 Guides authored
0 Guide Comments
Past 24 Hours: 4
Past 7 Days: 16
Past 30 Days: 88
All Time: 874
