Up to 20% off select tools
Samsung Moment Camera Button Replacement
Views: 1.5K
View statistics:
Past 24 Hours:
2
Past 7 Days:
24
Past 30 Days:
96
All Time:
1,480
Comments: 0
Go to guide comments
Completed: 3
3 people have marked this guide "completed." Will you be next?
Favorites: 4
4 people have favorited (and subscribed to) this guide. Will you be next?
Time Required: 10 - 15 minutes
Difficulty: Moderate
Action Shots
Be an action hero! This guide needs images that better demonstrate how to perform specific actions.
Markup Mishap
This guide needs better markups. Help out by correcting or making some markup annotations.
Community-Contributed Guide
Missing Details
Some of this guide's details are missing. Help users by adding tools, difficulty, or time.
Parts
Tools
  • Spudger
    4.9
  • Phillips #000 Screwdriver
    4.9
Introduction
Go to step 1 ↓
This guide details how to install a new camera button on your Samsung Moment SPH M900. The camera button is located on the lower right side, distinguished by a black line. We provide directions for both disassembly and reassembly.
    1. Samsung Moment Camera Button Replacement, Camera Button: step 1, image 1 of 3 Samsung Moment Camera Button Replacement, Camera Button: step 1, image 2 of 3 Samsung Moment Camera Button Replacement, Camera Button: step 1, image 3 of 3
      • Power off the phone using the "Power Button", the circular middle button in the center of the phone.
      • Locate the camera button on bottom right side of your phone
      • Remove the back panel of the phone by sliding the spudger along the edge of the phone. The rear plastic panel will snap off from the remainder of the phone.
      Ask FixBot
    2. Samsung Moment Camera Button Replacement: step 2, image 1 of 1
      • Remove the battery from the phone by pulling up on the battery edge.
      Ask FixBot
    3. Samsung Moment Camera Button Replacement: step 3, image 1 of 1
      • If you have not already removed the memory card, remove it by gently sliding it out of its holder.
      Ask FixBot
    4. Samsung Moment Camera Button Replacement: step 4, image 1 of 3 Samsung Moment Camera Button Replacement: step 4, image 2 of 3 Samsung Moment Camera Button Replacement: step 4, image 3 of 3
      • Using the small Phillips #000 screw driver, remove the six screws from the back of the phone.
      • Using the spudger tool, separate the back housing from the phone.
      • While separating the back house from the phone, the three buttons (the volume, the speaker, and the camera button) might fall out. Be sure to keep track of these three buttons and use them for reassembly.
      Ask FixBot
    5. Samsung Moment Camera Button Replacement: step 5, image 1 of 2 Samsung Moment Camera Button Replacement: step 5, image 2 of 2
      Tool used on this step:
      Buy
      • If the camera button did not fall, carefully remove it using a pair of tweezers. At this point, you can replace the button with a new one.
      Ask FixBot
Be sure to gently slide the memory card back in its holder.
3 other people completed this guide.
Author
with
Allison Coffee
214 Reputation
1 Guide authored
0 Guide Comments
Past 24 Hours: 2
Past 7 Days: 24
Past 30 Days: 96
All Time: 1,480
