Up to 20% off select tools
Samsung MV900F Screen Replacement
Views: 2K
View statistics:
Past 24 Hours:
6
Past 7 Days:
22
Past 30 Days:
99
All Time:
1,984
Comments: 2
1 comment on steps, 1 guide comment.
Go to guide comments
Completed: 0
Favorites: 0
Time Required: 5 - 10 minutes
Difficulty: Moderate
Parts
Tools
Introduction
Go to step 1 ↓
This guide will demonstrate eight steps on how to replace the flip screen on a Samsung MV900F Smart Camera.
    1. Samsung MV900F Screen Replacement, Battery: step 1, image 1 of 1
      • Slide the lock towards the middle of the camera, in the same direction of the arrow.
      Ask FixBot
    2. Samsung MV900F Screen Replacement: step 2, image 1 of 1
      • Push the blue battery holder up in the direction of the arrow.
      Ask FixBot
    3. Samsung MV900F Screen Replacement: step 3, image 1 of 1
      • Pull the battery out of the battery slot.
      Ask FixBot
    1. Samsung MV900F Screen Replacement, Screen: step 4, image 1 of 2 Samsung MV900F Screen Replacement, Screen: step 4, image 2 of 2
      Tool used on this step:
      Buy
      • Use tweezers to remove the four rubber screw covers.
      Ask FixBot
    2. Samsung MV900F Screen Replacement: step 5, image 1 of 2 Samsung MV900F Screen Replacement: step 5, image 2 of 2
      • Remove the four Phillips 2.381 mm screws on back side of camera and one Phillips 2.381 mm screw on the bottom of the camera, using a Phillips #00 screwdriver.
      Ask FixBot
    3. Samsung MV900F Screen Replacement: step 6, image 1 of 1
      • Remove the back casing by just carefully pulling the casing off of the camera.
      Ask FixBot
    4. Samsung MV900F Screen Replacement: step 7, image 1 of 1
      • Use the Phillips #00 screw driver to remove the four 2.381 mm screws next to the screen hinge.
      Ask FixBot
    5. Samsung MV900F Screen Replacement: step 8, image 1 of 1
      • Use plastic opening tool to disconnect screen connector from the control board.
      Ask FixBot
    6. Samsung MV900F Screen Replacement: step 9, image 1 of 1
      • Remove the old screen.
      Ask FixBot
To reassemble your device, follow these steps in reverse order.
Author
with
Ethan Rowland
216 Reputation
2 Guides authored
1 Guide Comment
Anyone an Idea where I can buy a cheap new display for that cam?
Bernhard Prieler - Reply Share
Past 24 Hours: 6
Past 7 Days: 22
Past 30 Days: 99
All Time: 1,984
