Samsung MV900F Flash Bulb Assembly Replacement
    1. Samsung MV900F Flash Bulb Assembly Replacement, Battery: step 1, image 1 of 1
      • Slide the lock towards the middle of the camera, in the same direction of the arrow.
      Ask FixBot
    2. Samsung MV900F Flash Bulb Assembly Replacement: step 2, image 1 of 1
      • Push the blue battery holder up in the direction of the arrow.
      Ask FixBot
    3. Samsung MV900F Flash Bulb Assembly Replacement: step 3, image 1 of 1
      • Pull the battery out of the battery slot.
      Ask FixBot
    1. Samsung MV900F Flash Bulb Assembly Replacement, Screen: step 4, image 1 of 2 Samsung MV900F Flash Bulb Assembly Replacement, Screen: step 4, image 2 of 2
      Tool used on this step:
      Buy
      • Use tweezers to remove the four rubber screw covers.
      Ask FixBot
    2. Samsung MV900F Flash Bulb Assembly Replacement: step 5, image 1 of 2 Samsung MV900F Flash Bulb Assembly Replacement: step 5, image 2 of 2
      • Remove the four Phillips 2.381 mm screws on back side of camera and one Phillips 2.381 mm screw on the bottom of the camera, using a Phillips #00 screwdriver.
      Ask FixBot
    3. Samsung MV900F Flash Bulb Assembly Replacement: step 6, image 1 of 1
      • Remove the back casing by just carefully pulling the casing off of the camera.
      Ask FixBot
    4. Samsung MV900F Flash Bulb Assembly Replacement: step 7, image 1 of 1
      • Use the Phillips #00 screw driver to remove the four 2.381 mm screws next to the screen hinge.
      Ask FixBot
    5. Samsung MV900F Flash Bulb Assembly Replacement: step 8, image 1 of 1
      • Use plastic opening tool to disconnect screen connector from the control board.
      Ask FixBot
    6. Samsung MV900F Flash Bulb Assembly Replacement: step 9, image 1 of 1
      • Remove the old screen.
      Ask FixBot
    1. Samsung MV900F Flash Bulb Assembly Replacement, Lens Assembly: step 10, image 1 of 1
      • Remove the 2.381 mm screw with a Phillips #00 screwdriver.
      Ask FixBot
    2. Samsung MV900F Flash Bulb Assembly Replacement: step 11, image 1 of 1
      • Use the plastic opening tool to remove the silver metal lens cover.
      Ask FixBot
    3. Samsung MV900F Flash Bulb Assembly Replacement: step 12, image 1 of 1
      Buy
      • Use the tweezers to remove the black electrical tape covering the copper connector to the control board.
      Ask FixBot
    4. Samsung MV900F Flash Bulb Assembly Replacement: step 13, image 1 of 1
      • From the front of the camera, push the lens through the back of the camer.a
      Ask FixBot
    5. Samsung MV900F Flash Bulb Assembly Replacement: step 14, image 1 of 2 Samsung MV900F Flash Bulb Assembly Replacement: step 14, image 2 of 2
      • Use a pair of tweezers to flip up the black retaining bar on each of the two ZIF connectors.
      Ask FixBot
    6. Samsung MV900F Flash Bulb Assembly Replacement: step 15, image 1 of 2 Samsung MV900F Flash Bulb Assembly Replacement: step 15, image 2 of 2
      • Remove the lens assembly from the camera.
      Ask FixBot
    1. Samsung MV900F Flash Bulb Assembly Replacement, Flash Bulb Assembly: step 16, image 1 of 1
      • Remove the 2.381 mm screw that is holding the copper to the control board with a Phillips #00 screw driver.
      Ask FixBot
    2. Samsung MV900F Flash Bulb Assembly Replacement: step 17, image 1 of 1
      Buy
      • Use tweezers to pull copper connector from the control board.
      Ask FixBot
    3. Samsung MV900F Flash Bulb Assembly Replacement: step 18, image 1 of 1
      • Use the plastic opening tool to pry the control board up, thus allowing the flash bulb assembly to be removed.
      Ask FixBot
    4. Samsung MV900F Flash Bulb Assembly Replacement: step 19, image 1 of 1
      • Beginning with the battery on the side, gently pull upwards to remove the entire flash bulb assembly.
      Ask FixBot
Justin Smith
122 Reputation
1 Guide authored
0 Guide Comments
Past 24 Hours: 1
Past 7 Days: 5
Past 30 Days: 30
All Time: 768
