Samsung ML2510 Side Cooling Fan Replacement
Views: 3.1K
View statistics:
Past 24 Hours:
2
Past 7 Days:
12
Past 30 Days:
75
All Time:
3,115
Comments: 0
Go to guide comments
Completed: 2
2 people have marked this guide "completed." Will you be next?
Favorites: 0
Time Required: 15 - 20 minutes
Difficulty: Moderate
Introduction
Go to step 1 ↓
This guide will require you to disassemble the back and side panel of the printer. You will need to refer to the Removing Samsung ML2510 Back Panel guide in order to complete the task.
Tools
    1. Samsung ML2510 Side Cooling Fan Replacement, Removing Samsung ML2510 Back Panel: step 1, image 1 of 3 Samsung ML2510 Side Cooling Fan Replacement, Removing Samsung ML2510 Back Panel: step 1, image 2 of 3 Samsung ML2510 Side Cooling Fan Replacement, Removing Samsung ML2510 Back Panel: step 1, image 3 of 3
      • Remove the top hinged panel by taking out the pins at the bottom of this panel.
      Ask FixBot
    2. Samsung ML2510 Side Cooling Fan Replacement: step 2, image 1 of 1
      • Using a Phillips #2 screwdriver, remove the four screws on the back of the printer.
      Ask FixBot
    3. Samsung ML2510 Side Cooling Fan Replacement: step 3, image 1 of 3 Samsung ML2510 Side Cooling Fan Replacement: step 3, image 2 of 3 Samsung ML2510 Side Cooling Fan Replacement: step 3, image 3 of 3
      • Gently lift the top panel while simultaneously pulling off the back panel.
      • Before pulling out the back panel entirely, make sure to remove the rear cooling fan from its slot.
      Ask FixBot
    1. Samsung ML2510 Side Cooling Fan Replacement, Side Cooling Fan: step 4, image 1 of 3 Samsung ML2510 Side Cooling Fan Replacement, Side Cooling Fan: step 4, image 2 of 3 Samsung ML2510 Side Cooling Fan Replacement, Side Cooling Fan: step 4, image 3 of 3
      • Locate the holes on the panel that are attached to the main body.
      • Remove the front panel by gently moving the holes from the pegs one by one.
      Ask FixBot
    2. Samsung ML2510 Side Cooling Fan Replacement: step 5, image 1 of 1
      • Using a Phillips #2 screwdriver, remove the two 1" screws on the front face of the printer.
      Ask FixBot
    3. Samsung ML2510 Side Cooling Fan Replacement: step 6, image 1 of 3 Samsung ML2510 Side Cooling Fan Replacement: step 6, image 2 of 3 Samsung ML2510 Side Cooling Fan Replacement: step 6, image 3 of 3
      • Using a plastic opening tool, gently lift one side of the top panel from its peg.
      • Repeat process for the other side.
      • Lift the top panel from the front to remove it entirely.
      Ask FixBot
    4. Samsung ML2510 Side Cooling Fan Replacement: step 7, image 1 of 3 Samsung ML2510 Side Cooling Fan Replacement: step 7, image 2 of 3 Samsung ML2510 Side Cooling Fan Replacement: step 7, image 3 of 3
      • Lift the right side-panel up from the raised stops.
      • Gently rotate the panel as indicated in the picture to remove the panel entirely.
      Ask FixBot
    5. Samsung ML2510 Side Cooling Fan Replacement: step 8, image 1 of 1
      • Poke out the side fan from the inside of the printer.
      Ask FixBot
    6. Samsung ML2510 Side Cooling Fan Replacement: step 9, image 1 of 1
      • Unplug the fan's wires from the side circuit board.
      • Replace the fan and reassemble the printer using reverse procedures.
      Ask FixBot
2 other people completed this guide.
bbaustin
268 Reputation
6 Guides authored
Cal Poly, Team 17-18, Regan Fall 2011 Member of Cal Poly, Team 17-18, Regan Fall 2011
CPSU-REGAN-F11S17G18
4 Members
72 Guides authored
0 Guide Comments
Past 24 Hours: 2
Past 7 Days: 12
Past 30 Days: 75
All Time: 3,115
