Samsung ML2510 Rear Cooling Fan Replacement
  1. Samsung ML2510 Rear Cooling Fan Replacement, Removing Samsung ML2510 Back Panel: step 1, image 1 of 3 Samsung ML2510 Rear Cooling Fan Replacement, Removing Samsung ML2510 Back Panel: step 1, image 2 of 3 Samsung ML2510 Rear Cooling Fan Replacement, Removing Samsung ML2510 Back Panel: step 1, image 3 of 3
    • Remove the top hinged panel by taking out the pins at the bottom of this panel.
    Ask FixBot
  2. Samsung ML2510 Rear Cooling Fan Replacement: step 2, image 1 of 1
    • Using a Phillips #2 screwdriver, remove the four screws on the back of the printer.
    Ask FixBot
  3. Samsung ML2510 Rear Cooling Fan Replacement: step 3, image 1 of 3 Samsung ML2510 Rear Cooling Fan Replacement: step 3, image 2 of 3 Samsung ML2510 Rear Cooling Fan Replacement: step 3, image 3 of 3
    • Gently lift the top panel while simultaneously pulling off the back panel.
    • Before pulling out the back panel entirely, make sure to remove the rear cooling fan from its slot.
    Ask FixBot
  4. Samsung ML2510 Rear Cooling Fan Replacement, Rear Cooling Fan: step 4, image 1 of 2 Samsung ML2510 Rear Cooling Fan Replacement, Rear Cooling Fan: step 4, image 2 of 2
    • Once the fan is detached, unplug the fan from the circuit board.
    • Slide the fan's wiring through the anchored slit.
    Ask FixBot
  5. Samsung ML2510 Rear Cooling Fan Replacement: step 5, image 1 of 1
    • With the new fan, thread the wiring through the old fan's slit.
    • Reconnect the fan by plugging it back into the circuit board.
    • Reattach the back panel following these instructions in reverse order.
    Ask FixBot
Finish Line
bbaustin
268 Reputation
6 Guides authored
Cal Poly, Team 17-18, Regan Fall 2011 Member of Cal Poly, Team 17-18, Regan Fall 2011
CPSU-REGAN-F11S17G18
4 Members
12 Guides authored
1 Guide Comment
My printer is in this state currently. What is the type of fan (brand/specs) that needs to be installed? And perhaps also, where does one obtain such a fan?
Bax Bagatelli - Reply Share
Past 24 Hours: 1
Past 7 Days: 9
Past 30 Days: 47
All Time: 3,818
