Up to 20% off select tools
Samsung ML2510 Power Button Replacement
Views: 4K
View statistics:
Past 24 Hours:
3
Past 7 Days:
19
Past 30 Days:
98
All Time:
3,959
Comments: 0
Go to guide comments
Completed: 2
2 people have marked this guide "completed." Will you be next?
Favorites: 0
Time Required: 20 - 25 minutes
Difficulty: Moderate
Better Introduction
Improve this guide by completing or revising its introduction.
Tools
Introduction
Go to step 1 ↓
This guide will help you to replace the power button of your Samsung ML2510 laser printer.
    1. Samsung ML2510 Power Button Replacement, Removing Samsung ML2510 Back Panel: step 1, image 1 of 3 Samsung ML2510 Power Button Replacement, Removing Samsung ML2510 Back Panel: step 1, image 2 of 3 Samsung ML2510 Power Button Replacement, Removing Samsung ML2510 Back Panel: step 1, image 3 of 3
      • Remove the top hinged panel by taking out the pins at the bottom of this panel.
      Ask FixBot
    2. Samsung ML2510 Power Button Replacement: step 2, image 1 of 1
      • Using a Phillips #2 screwdriver, remove the four screws on the back of the printer.
      Ask FixBot
    3. Samsung ML2510 Power Button Replacement: step 3, image 1 of 3 Samsung ML2510 Power Button Replacement: step 3, image 2 of 3 Samsung ML2510 Power Button Replacement: step 3, image 3 of 3
      • Gently lift the top panel while simultaneously pulling off the back panel.
      • Before pulling out the back panel entirely, make sure to remove the rear cooling fan from its slot.
      Ask FixBot
    1. Samsung ML2510 Power Button Replacement, Power Button: step 4, image 1 of 3 Samsung ML2510 Power Button Replacement, Power Button: step 4, image 2 of 3 Samsung ML2510 Power Button Replacement, Power Button: step 4, image 3 of 3
      • Remove the front panel by gently separating the holes on the panel from the pegs attached to the main printer body.
      Ask FixBot
    2. Samsung ML2510 Power Button Replacement: step 5, image 1 of 1
      • Using a Phillips #2 screwdriver, remove both 1" screws on the front face of the printer.
      Ask FixBot
    3. Samsung ML2510 Power Button Replacement: step 6, image 1 of 3 Samsung ML2510 Power Button Replacement: step 6, image 2 of 3 Samsung ML2510 Power Button Replacement: step 6, image 3 of 3
      • Using a plastic opening tool, gently lift one side of the top panel from its peg.
      • Repeat the last step to free the opposite side of the top panel.
      • Lift the top panel from the front to remove it entirely.
      • Turn over the top panel to reveal the button on the underside of the panel.
      Ask FixBot
    4. Samsung ML2510 Power Button Replacement: step 7, image 1 of 1
      • Using a Phillips #2 screwdriver, remove both 1" screws that secure the button to the underside of the top panel.
      Ask FixBot
    5. Samsung ML2510 Power Button Replacement: step 8, image 1 of 2 Samsung ML2510 Power Button Replacement: step 8, image 2 of 2
      • Remove the clear plastic piece and the orange button from the panel.
      • Remove the orange button and the spring from the clear plastic holder.
      • Replace the button and reassemble the printer following the directions in reverse order.
      Ask FixBot
Finish Line
2 other people completed this guide.
Author
with
bbaustin
268 Reputation
6 Guides authored
Cal Poly, Team 17-18, Regan Fall 2011 Member of Cal Poly, Team 17-18, Regan Fall 2011
CPSU-REGAN-F11S17G18
4 Members
72 Guides authored
0 Guide Comments
Past 24 Hours: 3
Past 7 Days: 19
Past 30 Days: 98
All Time: 3,959
