Samsung Level Box Mini Speakers Replacement
Views: 5.7K
View statistics:
Past 24 Hours:
5
Past 7 Days:
31
Past 30 Days:
113
All Time:
5,735
Comments: 9
7 comments on steps, 2 guide comments.
Go to guide comments
Completed: 6
6 people have marked this guide "completed." Will you be next?
Favorites: 0
Time Required: 30 minutes
Difficulty: Difficult
Better Introduction
Improve this guide by completing or revising its introduction.
Tools
    1. Samsung Level Box Mini Speakers Replacement, Battery: step 1, image 1 of 2 Samsung Level Box Mini Speakers Replacement, Battery: step 1, image 2 of 2
      Tool used on this step:
      Buy
      • Using a plastic opening tool, go around the edges of the rubber bottom. Insert the same tool under the edge of the rubber and swivel side to side. Continue moving it forward while peeling the plastic off with the precision tweezers.
      Ask FixBot
    2. Samsung Level Box Mini Speakers Replacement: step 2, image 1 of 1
      • Remove the six 4.5 mm Philips #1 screws from the bottom plate using the Screwdriver J00. Take off the bottom plate.
      Ask FixBot
    3. Samsung Level Box Mini Speakers Replacement: step 3, image 1 of 1
      • Using the plastic opening tool, remove the batteries from the device.
      Ask FixBot
    1. Samsung Level Box Mini Speakers Replacement, Speakers: step 4, image 1 of 2 Samsung Level Box Mini Speakers Replacement, Speakers: step 4, image 2 of 2
      • Remove the speaker grill from the device.
      Ask FixBot
    2. Samsung Level Box Mini Speakers Replacement: step 5, image 1 of 1
      • Remove the six 2.5 mm Philips #2 screws on the front of the device surrounding the speakers using the Screwdriver PH2 Philips Head.
      Ask FixBot
    3. Samsung Level Box Mini Speakers Replacement: step 6, image 1 of 3 Samsung Level Box Mini Speakers Replacement: step 6, image 2 of 3 Samsung Level Box Mini Speakers Replacement: step 6, image 3 of 3
      • Remove the eight 1.6 mm Philips #1 screws from the sides, front, and back of the device using the Screwdriver J000 Philips Head.
      Ask FixBot
    4. Samsung Level Box Mini Speakers Replacement: step 7, image 1 of 2 Samsung Level Box Mini Speakers Replacement: step 7, image 2 of 2
      • Gently tap the back of the device to remove the speakers.
      Ask FixBot
    5. Samsung Level Box Mini Speakers Replacement: step 8, image 1 of 1
      Anti-Static Wrist Strap
      $7.95
      Buy
      Ask FixBot
    6. Samsung Level Box Mini Speakers Replacement: step 9, image 1 of 1
      • To put the replacement speakers onto the device, use a soldering tool to solder the wires onto the new speakers.
      Ask FixBot
6 other people completed this guide.
Amanda Hymer
684 Reputation
2 Guides authored
USF Tampa, Team 1-4, Kass Spring 2017 Member of USF Tampa, Team 1-4, Kass Spring 2017
USFT-KASS-S17S1G4
5 Members
36 Guides authored
2 Guide Comments
Só tem esse video que mostra passo a passo como desmontar o Samsung Level Box Mini.
Obrigado por compartilhar amigo, espero que esse video ajude outras pessoas.
saulo_venancio - Reply Share
Samsung seviye kutusu mini ses gürültüsünü engelleyen hoparlörler, devreden çok yüksek perdeli bir ses alıyorum.
Alaybeyi - Reply Share
Past 24 Hours: 5
Past 7 Days: 31
Past 30 Days: 113
All Time: 5,735
