Up to 20% off select tools
Samsung Level Box Mini Buttons Replacement
Views: 2.3K
View statistics:
Past 24 Hours:
2
Past 7 Days:
16
Past 30 Days:
106
All Time:
2,270
Comments: 1
1 comment on steps.
Completed: 2
2 people have marked this guide "completed." Will you be next?
Favorites: 0
Time Required: 10 minutes
Difficulty: Moderate
Better Introduction
Improve this guide by completing or revising its introduction.
Tools
Introduction
Go to step 1 ↓
Samsung Level Box Mini button cleaning or replacement. Samsung Level Box Mini buttons not working.
    1. Samsung Level Box Mini Buttons Replacement, Buttons: step 1, image 1 of 2 Samsung Level Box Mini Buttons Replacement, Buttons: step 1, image 2 of 2
      Tool used on this step:
      Buy
      • Using a plastic opening tool, go around the edges of the rubber bottom. Insert the same tool under the edge of the rubber and swivel side to side. Continue moving it forward while peeling the plastic off with the precision tweezers.
      Ask FixBot
    2. Samsung Level Box Mini Buttons Replacement: step 2, image 1 of 1
      • Remove the six 4.5 mm Philips #1 screws from the bottom plate using the Screwdriver J00 Philips Head. Take off the bottom plate.
      Ask FixBot
    3. Samsung Level Box Mini Buttons Replacement: step 3, image 1 of 1
      • Using the plastic opening tool, remove the batteries from the device.
      Ask FixBot
    4. Samsung Level Box Mini Buttons Replacement: step 4, image 1 of 3 Samsung Level Box Mini Buttons Replacement: step 4, image 2 of 3 Samsung Level Box Mini Buttons Replacement: step 4, image 3 of 3
      • Remove the eight 1.6 mm Philips #1 screws from the sides, front, and back of the device using the Screwdriver J000 Philips Head.
      Ask FixBot
    5. Samsung Level Box Mini Buttons Replacement: step 5, image 1 of 1
      • Remove the top of the device using the metal spudger.
      Ask FixBot
    6. Samsung Level Box Mini Buttons Replacement: step 6, image 1 of 2 Samsung Level Box Mini Buttons Replacement: step 6, image 2 of 2
      • Clean the white plastic using a cloth. Remove the white plastic using the metal spudger.
      Ask FixBot
    7. Samsung Level Box Mini Buttons Replacement: step 7, image 1 of 1
      • Clean the top of the buttons using a cloth.
      Ask FixBot
2 other people completed this guide.
Author
with
Amanda Hymer
684 Reputation
2 Guides authored
USF Tampa, Team 1-4, Kass Spring 2017 Member of USF Tampa, Team 1-4, Kass Spring 2017
USFT-KASS-S17S1G4
5 Members
36 Guides authored
0 Guide Comments
Past 24 Hours: 2
Past 7 Days: 16
Past 30 Days: 106
All Time: 2,270
