Samsung LN-T5265F T-Con Board Replacement
  1. Samsung LN-T5265F T-Con Board Replacement, Stand: step 1, image 1 of 1
    • Lay the TV screen-side down on a flat, soft surface.
    • Remove four Phillips screws attaching the stand to the TV.
    Ask FixBot
    • Slide the stand out from the bottom of the TV.
    Ask FixBot
  2. Samsung LN-T5265F T-Con Board Replacement, Rear Case: step 3, image 1 of 2 Samsung LN-T5265F T-Con Board Replacement, Rear Case: step 3, image 2 of 2
    • Remove fifteen Phillips screws securing the rear case to the front.
    • If present, remove four Phillips screws for the VESA mount.
    • Carefully lift the rear case upwards to separate it from the frame of the TV.
    Ask FixBot
  3. Samsung LN-T5265F T-Con Board Replacement, T-Con Board: step 4, image 1 of 2 Samsung LN-T5265F T-Con Board Replacement, T-Con Board: step 4, image 2 of 2
    • The Timing Controller (T-Con) board is located at the top center behind a metal shield.
    • Remove four Phillips screws.
    • Tilt the metal shield towards the top of the TV and lift away.
    Ask FixBot
  4. Samsung LN-T5265F T-Con Board Replacement: step 5, image 1 of 1
    • Disconnect the two ribbon cables at the top by flipping up the retaining flaps and sliding the ribbons straight up towards the top of the TV.
    Ask FixBot
  5. Samsung LN-T5265F T-Con Board Replacement: step 6, image 1 of 1
    • Disconnect the bottom ribbon cable by depressing the two buttons on either side of the connector and sliding down towards the bottom of the TV.
    Ask FixBot
3 other people completed this guide.
Steven Carlton
630 Reputation
3 Guides authored
1 Guide Comment
A tv liga e desliga o que pode ser o reparo
Sidney pereira da Costa - Reply Share
Past 24 Hours: 0
Past 7 Days: 7
Past 30 Days: 40
All Time: 10,784
