Samsung L100 camera lens replacement
    1. Samsung L100 camera lens replacement, Removing Back Cover: step 1, image 1 of 3 Samsung L100 camera lens replacement, Removing Back Cover: step 1, image 2 of 3 Samsung L100 camera lens replacement, Removing Back Cover: step 1, image 3 of 3
      • Remove the six external screws from the camera using a Phillips #0 screwdriver.
      • After the screws has been removed, the bottom of the back half of the external case should be loosened from the camera.
      • Be careful, make sure you don't lose the screws.
      Ask FixBot
    2. Samsung L100 camera lens replacement: step 2, image 1 of 2 Samsung L100 camera lens replacement: step 2, image 2 of 2
      • Open the battery cover that's located on the bottom right side of the camera and carefully remove the battery.
      Ask FixBot
    3. Samsung L100 camera lens replacement: step 3, image 1 of 3 Samsung L100 camera lens replacement: step 3, image 2 of 3 Samsung L100 camera lens replacement: step 3, image 3 of 3
      • Slide your fingernail or a plastic spudger in the groove from the bottom to the top right side of the camera.
      Ask FixBot
    4. Samsung L100 camera lens replacement: step 4, image 1 of 1
      • Carefully squeeze the top right corner of the camera and pry off the external cover.
      • If you hear a "cracking" sound. This is normal.
      • Continue to pull the external cover and it will come off cleanly.
      • Be cautious of the flash capacitor. It carries an electrical charge, that may give you an unpleasant shock.
      Ask FixBot
    5. Samsung L100 camera lens replacement: step 5, image 1 of 1
      • Carefully pull off the back cover, parts behind the back of the case might fall out.
      Ask FixBot
    1. Samsung L100 camera lens replacement, Camera Lens: step 6, image 1 of 1
      • Remove the front cover, it comes off easily.
      • Buttons might fall out when you remove the front cover.
      Ask FixBot
    2. Samsung L100 camera lens replacement: step 7, image 1 of 1
      • Remove green tape from ribbon.
      Ask FixBot
    3. Samsung L100 camera lens replacement: step 8, image 1 of 2 Samsung L100 camera lens replacement: step 8, image 2 of 2
      • Remove four screws around lens.
      Ask FixBot
    4. Samsung L100 camera lens replacement: step 9, image 1 of 1
      • Use spudger to remove ribbon connecting the circuit board from lens.
      Ask FixBot
    5. Samsung L100 camera lens replacement: step 10, image 1 of 1
      • Remove lens from camera.
      Ask FixBot
6 other people completed this guide.
Adriel
135 Reputation
2 Guides authored
Cal Poly, Team 6-17, Maness Spring 2010 Member of Cal Poly, Team 6-17, Maness Spring 2010
CPSU-MANESS-S10S6G17
4 Members
60 Guides authored
0 Guide Comments
Past 24 Hours: 4
Past 7 Days: 17
Past 30 Days: 59
All Time: 10,992
