Up to 20% off select tools
Samsung L100 Setting Knob Spring
Views: 3.9K
View statistics:
Past 24 Hours:
2
Past 7 Days:
24
Past 30 Days:
103
All Time:
3,886
Comments: 1
1 comment on steps.
Completed: 0
Favorites: 0
Time Required: 15 minutes
Difficulty: Moderate
Parts
Tools
Introduction
Go to step 1 ↓
A guide to help replace the spring inside of the setting knob on top of the camera.
    1. Samsung L100 Setting Knob Spring, Removing Back Cover: step 1, image 1 of 3 Samsung L100 Setting Knob Spring, Removing Back Cover: step 1, image 2 of 3 Samsung L100 Setting Knob Spring, Removing Back Cover: step 1, image 3 of 3
      • Remove the six external screws from the camera using a Phillips #0 screwdriver.
      • After the screws has been removed, the bottom of the back half of the external case should be loosened from the camera.
      • Be careful, make sure you don't lose the screws.
      Ask FixBot
    2. Samsung L100 Setting Knob Spring: step 2, image 1 of 2 Samsung L100 Setting Knob Spring: step 2, image 2 of 2
      • Open the battery cover that's located on the bottom right side of the camera and carefully remove the battery.
      Ask FixBot
    3. Samsung L100 Setting Knob Spring: step 3, image 1 of 3 Samsung L100 Setting Knob Spring: step 3, image 2 of 3 Samsung L100 Setting Knob Spring: step 3, image 3 of 3
      • Slide your fingernail or a plastic spudger in the groove from the bottom to the top right side of the camera.
      Ask FixBot
    4. Samsung L100 Setting Knob Spring: step 4, image 1 of 1
      • Carefully squeeze the top right corner of the camera and pry off the external cover.
      • If you hear a "cracking" sound. This is normal.
      • Continue to pull the external cover and it will come off cleanly.
      • Be cautious of the flash capacitor. It carries an electrical charge, that may give you an unpleasant shock.
      Ask FixBot
    5. Samsung L100 Setting Knob Spring: step 5, image 1 of 1
      • Carefully pull off the back cover, parts behind the back of the case might fall out.
      Ask FixBot
    1. Samsung L100 Setting Knob Spring, Flash Circuit Board: step 6, image 1 of 1
      • Remove the screws holding the circuit board.
      • After you remove the screws, carefully remove the circuit board.
      Ask FixBot
    2. Samsung L100 Setting Knob Spring: step 7, image 1 of 2 Samsung L100 Setting Knob Spring: step 7, image 2 of 2
      • Remove the front cover, it comes off easily.
      • Buttons might fall out when you remove the front cover.
      Ask FixBot
    3. Samsung L100 Setting Knob Spring: step 8, image 1 of 1
      • Face camera towards you.
      • Remove the two screws from circuit board on the left side of the lens.
      Ask FixBot
    4. Samsung L100 Setting Knob Spring: step 9, image 1 of 1
      • Carefully hold up the circuit board, while it's still connected to the camera.
      • Remove all five screws that's on top of the camera.
      Ask FixBot
    5. Samsung L100 Setting Knob Spring: step 10, image 1 of 3 Samsung L100 Setting Knob Spring: step 10, image 2 of 3 Samsung L100 Setting Knob Spring: step 10, image 3 of 3
      • Carefully push up the top of the circuit board.
      • Pull up flash circuit board from top of camera.
      Ask FixBot
    1. Samsung L100 Setting Knob Spring, Setting Knob Spring: step 11, image 1 of 1
      • Face the bottom of the Flash Circuit board towards you.
      • Remove the one screw that's located on the left side of the lens.
      Ask FixBot
    2. Samsung L100 Setting Knob Spring: step 12, image 1 of 1
      • Take the flash circuit board and turn it over.
      • Remove the plastic setting knob.
      • Make sure to keep copper spring inside of the slot.
      Ask FixBot
    3. Samsung L100 Setting Knob Spring: step 13, image 1 of 3 Samsung L100 Setting Knob Spring: step 13, image 2 of 3 Samsung L100 Setting Knob Spring: step 13, image 3 of 3
      Tool used on this step:
      Buy
      • Take out and replace the Setting Knob Spring with tweezers.
      Ask FixBot
Author
with
andyhe
86 Reputation
1 Guide authored
Cal Poly, Team 6-17, Maness Spring 2010 Member of Cal Poly, Team 6-17, Maness Spring 2010
CPSU-MANESS-S10S6G17
4 Members
60 Guides authored
0 Guide Comments
Past 24 Hours: 2
Past 7 Days: 24
Past 30 Days: 103
All Time: 3,886
