Samsung Juke SCH-u470 Keyboard Replacement
    1. Samsung Juke SCH-u470 Keyboard Replacement, Battery: step 1, image 1 of 1
      • Press and hold down the button on the bottom side of the phone with your finger.
      Ask FixBot
    2. Samsung Juke SCH-u470 Keyboard Replacement: step 2, image 1 of 2 Samsung Juke SCH-u470 Keyboard Replacement: step 2, image 2 of 2
      • While holding the button down, remove the back cover of the phone.
      Ask FixBot
    1. Samsung Juke SCH-u470 Keyboard Replacement, Camera/Speaker: step 3, image 1 of 1
      • Remove the four screws from the back of the phone using a Phillips #00 screwdriver.
      Ask FixBot
    2. Samsung Juke SCH-u470 Keyboard Replacement: step 4, image 1 of 1
      • Remove the two 7.3 mm screws from the camera and the speaker at the bottom back plate of the phone using a Phillips #00 screwdriver.
      Ask FixBot
    3. Samsung Juke SCH-u470 Keyboard Replacement: step 5, image 1 of 3 Samsung Juke SCH-u470 Keyboard Replacement: step 5, image 2 of 3 Samsung Juke SCH-u470 Keyboard Replacement: step 5, image 3 of 3
      • Locate the USB port (where the charger can be plugged in). Using the iFixit opening tool, open the phone cover.
      • Failure to open USB port cover at this stage may result in damaging the device.
      Ask FixBot
    4. Samsung Juke SCH-u470 Keyboard Replacement: step 6, image 1 of 1
      • Remove the 5.5 mm screws from both sides of the camera/speaker with a Phillips #00 screwdriver.
      Ask FixBot
    5. Samsung Juke SCH-u470 Keyboard Replacement: step 7, image 1 of 2 Samsung Juke SCH-u470 Keyboard Replacement: step 7, image 2 of 2
      • Use the iFixit opening tool to remove the camera/speaker from the motherboard.
      • Practice caution to prevent damage to the attaching ribbon.
      Ask FixBot
    6. Samsung Juke SCH-u470 Keyboard Replacement: step 8, image 1 of 2 Samsung Juke SCH-u470 Keyboard Replacement: step 8, image 2 of 2
      • Use the iFixit opening tool to gently pry the camera/speaker off.
      Ask FixBot
    1. Samsung Juke SCH-u470 Keyboard Replacement, Motherboard: step 9, image 1 of 2 Samsung Juke SCH-u470 Keyboard Replacement, Motherboard: step 9, image 2 of 2
      • Use the iFixit opening tool to remove the yellow tab on the motherboard.
      Ask FixBot
    2. Samsung Juke SCH-u470 Keyboard Replacement: step 10, image 1 of 2 Samsung Juke SCH-u470 Keyboard Replacement: step 10, image 2 of 2
      • Use the iFixit opening tool to remove the other orange tab to free the motherboard.
      Ask FixBot
    3. Samsung Juke SCH-u470 Keyboard Replacement: step 11, image 1 of 3 Samsung Juke SCH-u470 Keyboard Replacement: step 11, image 2 of 3 Samsung Juke SCH-u470 Keyboard Replacement: step 11, image 3 of 3
      • To completely remove the motherboard, use the iFixit opening tool to leverage it up, then use your fingers to pull it out.
      • Do not be alarmed if the volume and hold buttons are removed from the motherboard.
      Ask FixBot
    1. Samsung Juke SCH-u470 Keyboard Replacement, Keyboard: step 12, image 1 of 3 Samsung Juke SCH-u470 Keyboard Replacement, Keyboard: step 12, image 2 of 3 Samsung Juke SCH-u470 Keyboard Replacement, Keyboard: step 12, image 3 of 3
      • Open/swivel the phone so the back of the LCD panel is visible.
      • Use the iFixit opening tool to pry the keypad from the hinge on the back of the device.
      • A moderate amount of force may need to be applied.
      Ask FixBot
Renee Kuzniar
94 Reputation
4 Guides authored
Cal Poly, Team 6-18, Maness Spring 2010 Member of Cal Poly, Team 6-18, Maness Spring 2010
CPSU-MANESS-S10S6G18
3 Members
72 Guides authored
0 Guide Comments
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 29
All Time: 2,433
