Up to 20% off select tools
Samsung Juke Outer Casing Replacement
Views: 3.1K
View statistics:
Past 24 Hours:
3
Past 7 Days:
15
Past 30 Days:
86
All Time:
3,100
Comments: 0
Go to guide comments
Completed: 2
2 people have marked this guide "completed." Will you be next?
Favorites: 1
1 person has favorited (and subscribed to) this guide. Will you be next?
Time Required: No estimate
Difficulty: Moderate
Needs Better Images
Better photos will improve this guide. Help out by taking, editing, or uploading new ones!
Tools
  • Spudger
    4.9
  • iFixit Opening Tool
    4.8
    1. Samsung Juke Outer Casing Replacement, Battery: step 1, image 1 of 1
      • Press and hold down the button on the bottom side of the phone with your finger.
      Ask FixBot
    2. Samsung Juke Outer Casing Replacement: step 2, image 1 of 2 Samsung Juke Outer Casing Replacement: step 2, image 2 of 2
      • While holding the button down, remove the back cover of the phone.
      Ask FixBot
    1. Samsung Juke Outer Casing Replacement, Camera/Speaker: step 3, image 1 of 1
      • Remove the four screws from the back of the phone using a Phillips #00 screwdriver.
      Ask FixBot
    2. Samsung Juke Outer Casing Replacement: step 4, image 1 of 1
      • Remove the two 7.3 mm screws from the camera and the speaker at the bottom back plate of the phone using a Phillips #00 screwdriver.
      Ask FixBot
    3. Samsung Juke Outer Casing Replacement: step 5, image 1 of 3 Samsung Juke Outer Casing Replacement: step 5, image 2 of 3 Samsung Juke Outer Casing Replacement: step 5, image 3 of 3
      • Locate the USB port (where the charger can be plugged in). Using the iFixit opening tool, open the phone cover.
      • Failure to open USB port cover at this stage may result in damaging the device.
      Ask FixBot
    4. Samsung Juke Outer Casing Replacement: step 6, image 1 of 1
      • Remove the 5.5 mm screws from both sides of the camera/speaker with a Phillips #00 screwdriver.
      Ask FixBot
    5. Samsung Juke Outer Casing Replacement: step 7, image 1 of 2 Samsung Juke Outer Casing Replacement: step 7, image 2 of 2
      • Use the iFixit opening tool to remove the camera/speaker from the motherboard.
      • Practice caution to prevent damage to the attaching ribbon.
      Ask FixBot
    6. Samsung Juke Outer Casing Replacement: step 8, image 1 of 2 Samsung Juke Outer Casing Replacement: step 8, image 2 of 2
      • Use the iFixit opening tool to gently pry the camera/speaker off.
      Ask FixBot
    1. Samsung Juke Outer Casing Replacement, Motherboard: step 9, image 1 of 2 Samsung Juke Outer Casing Replacement, Motherboard: step 9, image 2 of 2
      • Use the iFixit opening tool to remove the yellow tab on the motherboard.
      Ask FixBot
    2. Samsung Juke Outer Casing Replacement: step 10, image 1 of 2 Samsung Juke Outer Casing Replacement: step 10, image 2 of 2
      • Use the iFixit opening tool to remove the other orange tab to free the motherboard.
      Ask FixBot
    3. Samsung Juke Outer Casing Replacement: step 11, image 1 of 3 Samsung Juke Outer Casing Replacement: step 11, image 2 of 3 Samsung Juke Outer Casing Replacement: step 11, image 3 of 3
      • To completely remove the motherboard, use the iFixit opening tool to leverage it up, then use your fingers to pull it out.
      • Do not be alarmed if the volume and hold buttons are removed from the motherboard.
      Ask FixBot
    1. Samsung Juke Outer Casing Replacement, Keyboard: step 12, image 1 of 3 Samsung Juke Outer Casing Replacement, Keyboard: step 12, image 2 of 3 Samsung Juke Outer Casing Replacement, Keyboard: step 12, image 3 of 3
      • Open/swivel the phone so the back of the LCD panel is visible.
      • Use the iFixit opening tool to pry the keypad from the hinge on the back of the device.
      • A moderate amount of force may need to be applied.
      Ask FixBot
    1. Samsung Juke Outer Casing Replacement, Click Wheel: step 13, image 1 of 2 Samsung Juke Outer Casing Replacement, Click Wheel: step 13, image 2 of 2
      • Using your fingernail, remove the stickers covering the screws on the back of the LCD casing.
      • Remove six 3.5 mm screws from the back of the device using a Phillips #00 screwdriver.
      Ask FixBot
    2. Samsung Juke Outer Casing Replacement: step 14, image 1 of 3 Samsung Juke Outer Casing Replacement: step 14, image 2 of 3 Samsung Juke Outer Casing Replacement: step 14, image 3 of 3
      • Using a generous amount of force, use your hands to pry loose the casing from the LCD panel.
      • If necessary, use the iFixit opening tool to completely free the casing.
      • Be careful not to sever the wire connecting the outer casing to the display board.
      Ask FixBot
    3. Samsung Juke Outer Casing Replacement: step 15, image 1 of 3 Samsung Juke Outer Casing Replacement: step 15, image 2 of 3 Samsung Juke Outer Casing Replacement: step 15, image 3 of 3
      • Using the iFixit opening tool, remove the click wheel from the board.
      • After you have freed the edges, use the spudger to release the clip holding it flush to the board.
      Ask FixBot
    4. Samsung Juke Outer Casing Replacement: step 16, image 1 of 3 Samsung Juke Outer Casing Replacement: step 16, image 2 of 3 Samsung Juke Outer Casing Replacement: step 16, image 3 of 3
      • Unlock the ribbon connection by pressing down on the black clip.
      • Carefully pull the click wheel away from the device.
      Ask FixBot
    1. Samsung Juke Outer Casing Replacement, Outer Casing: step 17, image 1 of 2 Samsung Juke Outer Casing Replacement, Outer Casing: step 17, image 2 of 2
      Tool used on this step:
      Buy
      • Using tweezers, grip the red and blue wires that attach the audio earpiece to the outer casing and pull.
      • This is glued on so a moderate amount of force may be needed.
      Ask FixBot
2 other people completed this guide.
Author
with
Ryan Turner
107 Reputation
2 Guides authored
Cal Poly, Team 6-18, Maness Spring 2010 Member of Cal Poly, Team 6-18, Maness Spring 2010
CPSU-MANESS-S10S6G18
3 Members
72 Guides authored
0 Guide Comments
Past 24 Hours: 3
Past 7 Days: 15
Past 30 Days: 86
All Time: 3,100
