Up to 20% off select tools
Samsung Juke Motherboard Replacement
Views: 3.7K
View statistics:
Past 24 Hours:
3
Past 7 Days:
23
Past 30 Days:
90
All Time:
3,746
Comments: 0
Go to guide comments
Completed: 2
2 people have marked this guide "completed." Will you be next?
Favorites: 1
1 person has favorited (and subscribed to) this guide. Will you be next?
Time Required: No estimate
Difficulty: Easy
Better Introduction
Improve this guide by completing or revising its introduction.
Missing Details
Some of this guide's details are missing. Help users by adding tools, difficulty, or time.
Parts
Tools
Introduction
Go to step 1 ↓
This guide is a step-by-step guide on how to replace a Samsung Juke motherboard.
    1. Samsung Juke Motherboard Replacement, Battery: step 1, image 1 of 1
      • Press and hold down the button on the bottom side of the phone with your finger.
      Ask FixBot
    2. Samsung Juke Motherboard Replacement: step 2, image 1 of 2 Samsung Juke Motherboard Replacement: step 2, image 2 of 2
      • While holding the button down, remove the back cover of the phone.
      Ask FixBot
    1. Samsung Juke Motherboard Replacement, Camera/Speaker: step 3, image 1 of 1
      • Remove the four screws from the back of the phone using a Phillips #00 screwdriver.
      Ask FixBot
    2. Samsung Juke Motherboard Replacement: step 4, image 1 of 1
      • Remove the two 7.3 mm screws from the camera and the speaker at the bottom back plate of the phone using a Phillips #00 screwdriver.
      Ask FixBot
    3. Samsung Juke Motherboard Replacement: step 5, image 1 of 3 Samsung Juke Motherboard Replacement: step 5, image 2 of 3 Samsung Juke Motherboard Replacement: step 5, image 3 of 3
      • Locate the USB port (where the charger can be plugged in). Using the iFixit opening tool, open the phone cover.
      • Failure to open USB port cover at this stage may result in damaging the device.
      Ask FixBot
    4. Samsung Juke Motherboard Replacement: step 6, image 1 of 1
      • Remove the 5.5 mm screws from both sides of the camera/speaker with a Phillips #00 screwdriver.
      Ask FixBot
    5. Samsung Juke Motherboard Replacement: step 7, image 1 of 2 Samsung Juke Motherboard Replacement: step 7, image 2 of 2
      • Use the iFixit opening tool to remove the camera/speaker from the motherboard.
      • Practice caution to prevent damage to the attaching ribbon.
      Ask FixBot
    6. Samsung Juke Motherboard Replacement: step 8, image 1 of 2 Samsung Juke Motherboard Replacement: step 8, image 2 of 2
      • Use the iFixit opening tool to gently pry the camera/speaker off.
      Ask FixBot
    1. Samsung Juke Motherboard Replacement, Motherboard: step 9, image 1 of 2 Samsung Juke Motherboard Replacement, Motherboard: step 9, image 2 of 2
      • Use the iFixit opening tool to remove the yellow tab on the motherboard.
      Ask FixBot
    2. Samsung Juke Motherboard Replacement: step 10, image 1 of 2 Samsung Juke Motherboard Replacement: step 10, image 2 of 2
      • Use the iFixit opening tool to remove the other orange tab to free the motherboard.
      Ask FixBot
    3. Samsung Juke Motherboard Replacement: step 11, image 1 of 3 Samsung Juke Motherboard Replacement: step 11, image 2 of 3 Samsung Juke Motherboard Replacement: step 11, image 3 of 3
      • To completely remove the motherboard, use the iFixit opening tool to leverage it up, then use your fingers to pull it out.
      • Do not be alarmed if the volume and hold buttons are removed from the motherboard.
      Ask FixBot
2 other people completed this guide.
Author
with
Renee Kuzniar
94 Reputation
4 Guides authored
Cal Poly, Team 6-18, Maness Spring 2010 Member of Cal Poly, Team 6-18, Maness Spring 2010
CPSU-MANESS-S10S6G18
3 Members
72 Guides authored
0 Guide Comments
Past 24 Hours: 3
Past 7 Days: 23
Past 30 Days: 90
All Time: 3,746
