Up to 20% off select tools
Samsung Juke Click Wheel Replacement
Views: 4.2K
View statistics:
Past 24 Hours:
2
Past 7 Days:
23
Past 30 Days:
100
All Time:
4,165
Comments: 1
1 guide comment.
Go to guide comments
Completed: 1
1 person has marked this guide "completed." Will you be next?
Favorites: 2
2 people have favorited (and subscribed to) this guide. Will you be next?
Time Required: 15 - 20 minutes
Difficulty: Moderate
Needs Better Images
Better photos will improve this guide. Help out by taking, editing, or uploading new ones!
Tools
Introduction
Go to step 1 ↓
Use this guide to replace the click wheel on a Samsung Juke. The click wheel is an essential part of a Samsung Juke since its main function is to navigate through the phone and music player. If the click wheel is malfunctioning, you cannot access the Home Screen and music player.
Before starting your repair, make sure to turn off the phone. Failure to do so can damage the motherboard.
    1. Samsung Juke Click Wheel Replacement, Battery: step 1, image 1 of 1
      • Press and hold down the button on the bottom side of the phone with your finger.
      Ask FixBot
    2. Samsung Juke Click Wheel Replacement: step 2, image 1 of 2 Samsung Juke Click Wheel Replacement: step 2, image 2 of 2
      • While holding the button down, remove the back cover of the phone.
      Ask FixBot
    1. Samsung Juke Click Wheel Replacement, Camera/Speaker: step 3, image 1 of 1
      • Remove the four screws from the back of the phone using a Phillips #00 screwdriver.
      Ask FixBot
    2. Samsung Juke Click Wheel Replacement: step 4, image 1 of 1
      • Remove the two 7.3 mm screws from the camera and the speaker at the bottom back plate of the phone using a Phillips #00 screwdriver.
      Ask FixBot
    3. Samsung Juke Click Wheel Replacement: step 5, image 1 of 3 Samsung Juke Click Wheel Replacement: step 5, image 2 of 3 Samsung Juke Click Wheel Replacement: step 5, image 3 of 3
      • Locate the USB port (where the charger can be plugged in). Using the iFixit opening tool, open the phone cover.
      • Failure to open USB port cover at this stage may result in damaging the device.
      Ask FixBot
    4. Samsung Juke Click Wheel Replacement: step 6, image 1 of 1
      • Remove the 5.5 mm screws from both sides of the camera/speaker with a Phillips #00 screwdriver.
      Ask FixBot
    5. Samsung Juke Click Wheel Replacement: step 7, image 1 of 2 Samsung Juke Click Wheel Replacement: step 7, image 2 of 2
      • Use the iFixit opening tool to remove the camera/speaker from the motherboard.
      • Practice caution to prevent damage to the attaching ribbon.
      Ask FixBot
    6. Samsung Juke Click Wheel Replacement: step 8, image 1 of 2 Samsung Juke Click Wheel Replacement: step 8, image 2 of 2
      • Use the iFixit opening tool to gently pry the camera/speaker off.
      Ask FixBot
    1. Samsung Juke Click Wheel Replacement, Motherboard: step 9, image 1 of 2 Samsung Juke Click Wheel Replacement, Motherboard: step 9, image 2 of 2
      • Use the iFixit opening tool to remove the yellow tab on the motherboard.
      Ask FixBot
    2. Samsung Juke Click Wheel Replacement: step 10, image 1 of 2 Samsung Juke Click Wheel Replacement: step 10, image 2 of 2
      • Use the iFixit opening tool to remove the other orange tab to free the motherboard.
      Ask FixBot
    3. Samsung Juke Click Wheel Replacement: step 11, image 1 of 3 Samsung Juke Click Wheel Replacement: step 11, image 2 of 3 Samsung Juke Click Wheel Replacement: step 11, image 3 of 3
      • To completely remove the motherboard, use the iFixit opening tool to leverage it up, then use your fingers to pull it out.
      • Do not be alarmed if the volume and hold buttons are removed from the motherboard.
      Ask FixBot
    1. Samsung Juke Click Wheel Replacement, Keyboard: step 12, image 1 of 3 Samsung Juke Click Wheel Replacement, Keyboard: step 12, image 2 of 3 Samsung Juke Click Wheel Replacement, Keyboard: step 12, image 3 of 3
      • Open/swivel the phone so the back of the LCD panel is visible.
      • Use the iFixit opening tool to pry the keypad from the hinge on the back of the device.
      • A moderate amount of force may need to be applied.
      Ask FixBot
    1. Samsung Juke Click Wheel Replacement, Click Wheel: step 13, image 1 of 2 Samsung Juke Click Wheel Replacement, Click Wheel: step 13, image 2 of 2
      • Using your fingernail, remove the stickers covering the screws on the back of the LCD casing.
      • Remove six 3.5 mm screws from the back of the device using a Phillips #00 screwdriver.
      Ask FixBot
    2. Samsung Juke Click Wheel Replacement: step 14, image 1 of 3 Samsung Juke Click Wheel Replacement: step 14, image 2 of 3 Samsung Juke Click Wheel Replacement: step 14, image 3 of 3
      • Using a generous amount of force, use your hands to pry loose the casing from the LCD panel.
      • If necessary, use the iFixit opening tool to completely free the casing.
      • Be careful not to sever the wire connecting the outer casing to the display board.
      Ask FixBot
    3. Samsung Juke Click Wheel Replacement: step 15, image 1 of 3 Samsung Juke Click Wheel Replacement: step 15, image 2 of 3 Samsung Juke Click Wheel Replacement: step 15, image 3 of 3
      • Using the iFixit opening tool, remove the click wheel from the board.
      • After you have freed the edges, use the spudger to release the clip holding it flush to the board.
      Ask FixBot
    4. Samsung Juke Click Wheel Replacement: step 16, image 1 of 3 Samsung Juke Click Wheel Replacement: step 16, image 2 of 3 Samsung Juke Click Wheel Replacement: step 16, image 3 of 3
      • Unlock the ribbon connection by pressing down on the black clip.
      • Carefully pull the click wheel away from the device.
      Ask FixBot
Author
with
Ryan Turner
107 Reputation
2 Guides authored
Cal Poly, Team 6-18, Maness Spring 2010 Member of Cal Poly, Team 6-18, Maness Spring 2010
CPSU-MANESS-S10S6G18
3 Members
72 Guides authored
1 Guide Comment
All I have to say is: THANK YOU!
My juke's click wheel got stuck, which was draining my battery. I followed the incredibly easy to understand instructions and pictures and was able to free my click wheel. I cleaned the wheel and put my phone back together by going backward though the instructions, turned on my phone, and IT WORKED PERFECTLY. This saved my from having to buy a new, large and extremely expensive phone.
Thank You so much for these great, step-by-step instructions!
Rachel Krebs - Reply Share
Past 24 Hours: 2
Past 7 Days: 23
Past 30 Days: 100
All Time: 4,165
