Samsung Juke Camera/Speaker Replacement
    1. Samsung Juke Camera/Speaker Replacement, Battery: step 1, image 1 of 1
      • Press and hold down the button on the bottom side of the phone with your finger.
      Ask FixBot
    2. Samsung Juke Camera/Speaker Replacement: step 2, image 1 of 2 Samsung Juke Camera/Speaker Replacement: step 2, image 2 of 2
      • While holding the button down, remove the back cover of the phone.
      Ask FixBot
    1. Samsung Juke Camera/Speaker Replacement, Camera/Speaker: step 3, image 1 of 1
      • Remove the four screws from the back of the phone using a Phillips #00 screwdriver.
      Ask FixBot
    2. Samsung Juke Camera/Speaker Replacement: step 4, image 1 of 1
      • Remove the two 7.3 mm screws from the camera and the speaker at the bottom back plate of the phone using a Phillips #00 screwdriver.
      Ask FixBot
    3. Samsung Juke Camera/Speaker Replacement: step 5, image 1 of 3 Samsung Juke Camera/Speaker Replacement: step 5, image 2 of 3 Samsung Juke Camera/Speaker Replacement: step 5, image 3 of 3
      • Locate the USB port (where the charger can be plugged in). Using the iFixit opening tool, open the phone cover.
      • Failure to open USB port cover at this stage may result in damaging the device.
      Ask FixBot
    4. Samsung Juke Camera/Speaker Replacement: step 6, image 1 of 1
      • Remove the 5.5 mm screws from both sides of the camera/speaker with a Phillips #00 screwdriver.
      Ask FixBot
    5. Samsung Juke Camera/Speaker Replacement: step 7, image 1 of 2 Samsung Juke Camera/Speaker Replacement: step 7, image 2 of 2
      • Use the iFixit opening tool to remove the camera/speaker from the motherboard.
      • Practice caution to prevent damage to the attaching ribbon.
      Ask FixBot
    6. Samsung Juke Camera/Speaker Replacement: step 8, image 1 of 2 Samsung Juke Camera/Speaker Replacement: step 8, image 2 of 2
      • Use the iFixit opening tool to gently pry the camera/speaker off.
      Ask FixBot
Renee Kuzniar
94 Reputation
4 Guides authored
Cal Poly, Team 6-18, Maness Spring 2010 Member of Cal Poly, Team 6-18, Maness Spring 2010
CPSU-MANESS-S10S6G18
3 Members
72 Guides authored
2 Guide Comments
Hey! Thank you for posting such an in-depth guide to repair and replacement for this phone!! I just recently booted mine back up again, and it's truly been a time capsule of what life was like back then. Everything has been running pretty smoothly up until I tested my speakers. Weirdly, it plays the start up/shut down sounds perfectly, but won't play any other sounds/songs even with the volume all the way up. Camera works just fine, so wondering if you have any suggestions outside of replacement? I still have to find an aux cord that fits to see if sound can come out of there; will keep y'all posted on that. Otherwise, I really appreciate any feedback y'all may have. Thanks again for the guidance!
Jess Garcia - Reply Share
Update: Found an aux cord that fits, it still doesn't emit any sound. I noticed how the aux cord doesn't feel fully secure on the inside, it kinda jiggles around. Let me know if there's any internal fixes I can try for this. Much appreciated <3
Past 24 Hours: 0
Past 7 Days: 3
Past 30 Days: 36
All Time: 4,046
