Up to 20% off select tools
Samsung Jack Rear Case Replacement
Views: 1.8K
View statistics:
Past 24 Hours:
2
Past 7 Days:
17
Past 30 Days:
91
All Time:
1,761
Comments: 0
Go to guide comments
Completed: 0
Favorites: 0
Time Required: 5 minutes
Difficulty: Moderate
Tools
Introduction
Go to step 1 ↓
Use this guide to install a rear case.
    1. Samsung Jack Rear Case Replacement, Battery: step 1, image 1 of 1
      • Slide the battery cover downwards with pressure focused on the center of the cover.
      • Lift the cover off of the phone.
      Ask FixBot
    2. Samsung Jack Rear Case Replacement: step 2, image 1 of 1
      • Grasp the bottom left and right corners of the battery and lift it from its housing.
      Ask FixBot
    1. Samsung Jack Rear Case Replacement, Rear Case: step 3, image 1 of 1
      • Remove the four black 7.30 mm screws surrounding the battery housing using a Phillips #00 Screwdriver.
      Ask FixBot
    2. Samsung Jack Rear Case Replacement: step 4, image 1 of 3 Samsung Jack Rear Case Replacement: step 4, image 2 of 3 Samsung Jack Rear Case Replacement: step 4, image 3 of 3
      • The rear case is firmly attached to the phone with clips. Do not be afraid to use a little extra force.
      • Insert the Plastic Opening Tool in between the front and rear cases.
      • Pry with the Plastic Opening Tool around all edges of the phone until you free all the clips.
      Ask FixBot
    3. Samsung Jack Rear Case Replacement: step 5, image 1 of 1
      • Lift the rear case off of the phone.
      Ask FixBot
Author
with
Paul Piller
56 Reputation
5 Guides authored
Cal Poly, Team 24-57, Amido Spring 2011 Member of Cal Poly, Team 24-57, Amido Spring 2011
CPSU-AMIDO-S11S24G57
4 Members
84 Guides authored
0 Guide Comments
Past 24 Hours: 2
Past 7 Days: 17
Past 30 Days: 91
All Time: 1,761
