Up to 20% off select tools
Samsung Jack LCD Replacement
Views: 2.6K
View statistics:
Past 24 Hours:
5
Past 7 Days:
19
Past 30 Days:
102
All Time:
2,555
Comments: 0
Go to guide comments
Completed: 1
1 person has marked this guide "completed." Will you be next?
Favorites: 0
Time Required: 15 minutes
Difficulty: Difficult
Tools
Introduction
Go to step 1 ↓
Use this guide to install a new LCD screen.
    1. Samsung Jack LCD Replacement, Battery: step 1, image 1 of 1
      • Slide the battery cover downwards with pressure focused on the center of the cover.
      • Lift the cover off of the phone.
      Ask FixBot
    2. Samsung Jack LCD Replacement: step 2, image 1 of 1
      • Grasp the bottom left and right corners of the battery and lift it from its housing.
      Ask FixBot
    1. Samsung Jack LCD Replacement, Rear Case: step 3, image 1 of 1
      • Remove the four black 7.30 mm screws surrounding the battery housing using a Phillips #00 Screwdriver.
      Ask FixBot
    2. Samsung Jack LCD Replacement: step 4, image 1 of 3 Samsung Jack LCD Replacement: step 4, image 2 of 3 Samsung Jack LCD Replacement: step 4, image 3 of 3
      • The rear case is firmly attached to the phone with clips. Do not be afraid to use a little extra force.
      • Insert the Plastic Opening Tool in between the front and rear cases.
      • Pry with the Plastic Opening Tool around all edges of the phone until you free all the clips.
      Ask FixBot
    3. Samsung Jack LCD Replacement: step 5, image 1 of 1
      • Lift the rear case off of the phone.
      Ask FixBot
    1. Samsung Jack LCD Replacement, Antenna: step 6, image 1 of 1
      • Remove the two silver 4.30 mm screws on either side of the antenna using a Phillip's #00 Screwdriver.
      Ask FixBot
    2. Samsung Jack LCD Replacement: step 7, image 1 of 3 Samsung Jack LCD Replacement: step 7, image 2 of 3 Samsung Jack LCD Replacement: step 7, image 3 of 3
      • There is a wire under the antenna connecting it to the Motherboard. Do not pull off the antenna just yet.
      • Use a spudger to remove the wire connector under the antenna.
      Ask FixBot
    1. Samsung Jack LCD Replacement, Speaker: step 8, image 1 of 1
      • Remove the two black 7.30 mm screws on the top right and left corners of the Motherboard using a Phillips #00 Screwdriver.
      • Remove the silver 4.50 mm screw located below the speaker using a Phillips #00 Screwdriver.
      Ask FixBot
    2. Samsung Jack LCD Replacement: step 9, image 1 of 2 Samsung Jack LCD Replacement: step 9, image 2 of 2
      • Use the spudger to detach the speaker ribbon cable.
      Ask FixBot
    3. Samsung Jack LCD Replacement: step 10, image 1 of 1
      • Lift the speaker out of its compartment.
      Ask FixBot
    1. Samsung Jack LCD Replacement, Motherboard: step 11, image 1 of 1
      • Remove the power and volume buttons on the right side of the Motherboard.
      Ask FixBot
    2. Samsung Jack LCD Replacement: step 12, image 1 of 2 Samsung Jack LCD Replacement: step 12, image 2 of 2
      • Use a spudger to detach the camera ribbon cable.
      • Lift the camera off of the Motherboard.
      Ask FixBot
    3. Samsung Jack LCD Replacement: step 13, image 1 of 2 Samsung Jack LCD Replacement: step 13, image 2 of 2
      • Use a spudger to disconnect the white antenna wire on the bottom right corner of the Motherboard.
      Ask FixBot
    4. Samsung Jack LCD Replacement: step 14, image 1 of 3 Samsung Jack LCD Replacement: step 14, image 2 of 3 Samsung Jack LCD Replacement: step 14, image 3 of 3
      • Use a Plastic Opening Tool to lift the flaps of the ZIF connectors to release the ribbon cables near the bottom of the Motherboard.
      • Use a spudger to carefully pull the ribbon cables away from the ZIF connectors.
      Ask FixBot
    5. Samsung Jack LCD Replacement: step 15, image 1 of 2 Samsung Jack LCD Replacement: step 15, image 2 of 2
      • There is a ribbon cable under the Motherboard connecting it to the LCD. Do not pull off the Motherboard just yet.
      • Insert the Plastic Opening Tool under the upper left corner of the Motherboard to help reveal the ribbon cable.
      • Use a spudger to disconnect the Motherboard ribbon cable.
      Ask FixBot
    6. Samsung Jack LCD Replacement: step 16, image 1 of 1
      • Lift the Motherboard off of the phone.
      Ask FixBot
    1. Samsung Jack LCD Replacement, LCD: step 17, image 1 of 3 Samsung Jack LCD Replacement, LCD: step 17, image 2 of 3 Samsung Jack LCD Replacement, LCD: step 17, image 3 of 3
      • The LCD frame is firmly attached to the phone with clips. Do not be afraid to use a little extra force.
      • Insert the Plastic Opening Tool between the LCD frame and the front case of the phone.
      • Slide the Plastic Opening Tool around the LCD frame to detach all of the clips.
      Ask FixBot
    2. Samsung Jack LCD Replacement: step 18, image 1 of 2 Samsung Jack LCD Replacement: step 18, image 2 of 2
      • Lift up the LCD frame.
      Ask FixBot
    3. Samsung Jack LCD Replacement: step 19, image 1 of 3 Samsung Jack LCD Replacement: step 19, image 2 of 3 Samsung Jack LCD Replacement: step 19, image 3 of 3
      • There is a hanging ribbon cable connected to the LCD screen that passes through the LCD frame.
      • Insert the spudger under the bottom left corner of the LCD screen.
      • Use the spudger to gently pry the LCD screen out of its frame.
      • Gently remove the screen from the frame.
      Ask FixBot
Author
with
Paul Piller
56 Reputation
5 Guides authored
Cal Poly, Team 24-57, Amido Spring 2011 Member of Cal Poly, Team 24-57, Amido Spring 2011
CPSU-AMIDO-S11S24G57
4 Members
84 Guides authored
0 Guide Comments
Past 24 Hours: 5
Past 7 Days: 19
Past 30 Days: 102
All Time: 2,555
