Up to 20% off select tools
Samsung Instinct Front Case Replacement
Views: 1.1K
View statistics:
Past 24 Hours:
0
Past 7 Days:
3
Past 30 Days:
17
All Time:
1,139
Comments: 0
Go to guide comments
Completed: 0
Favorites: 2
2 people have favorited (and subscribed to) this guide. Will you be next?
Time Required: 10 minutes
Difficulty: Moderate
Tools
    1. Samsung Instinct Front Case Replacement, Battery: step 1, image 1 of 1
      • Apply pressure to the back cover and slide it forward towards the camera.
      • Lift the back cover off the phone.
      Ask FixBot
    2. Samsung Instinct Front Case Replacement: step 2, image 1 of 1
      • Holding the phone firmly, use the notches to grip and lift up the battery.
      Ask FixBot
    1. Samsung Instinct Front Case Replacement, Back Case: step 3, image 1 of 1
      • Remove the four 4.45mm screws at the corners of the phone.
      Ask FixBot
    2. Samsung Instinct Front Case Replacement: step 4, image 1 of 2 Samsung Instinct Front Case Replacement: step 4, image 2 of 2
      • Use the plastic opening tool to unhinge the locks around the edges of the phone.
      • Do not worry about the inner components of the phone; they are not connected to this case.
      Ask FixBot
    3. Samsung Instinct Front Case Replacement: step 5, image 1 of 1
      • Lift the casing off of the phone.
      Ask FixBot
    1. Samsung Instinct Front Case Replacement, Antenna: step 6, image 1 of 1
      • With the screws removed, locate the antenna.
      Ask FixBot
    2. Samsung Instinct Front Case Replacement: step 7, image 1 of 1
      • Using a Phillips head screwdriver, remove the 4.50mm screw holding the antenna in place.
      Ask FixBot
    3. Samsung Instinct Front Case Replacement: step 8, image 1 of 1
      • Using the plastic opener tool, squeeze gently on the antenna cable connector and lift to remove the connector from its position.
      Ask FixBot
    4. Samsung Instinct Front Case Replacement: step 9, image 1 of 1
      • Gently lift up on the antenna and remove it from the back of the device.
      Ask FixBot
    1. Samsung Instinct Front Case Replacement, Front Case: step 10, image 1 of 1
      • Remove the two 3.50mm screws connecting the motherboard to the case.
      Ask FixBot
    2. Samsung Instinct Front Case Replacement: step 11, image 1 of 3 Samsung Instinct Front Case Replacement: step 11, image 2 of 3 Samsung Instinct Front Case Replacement: step 11, image 3 of 3
      • Use the plastic opener tool to detach the three ribbons on the motherboard.
      Ask FixBot
    3. Samsung Instinct Front Case Replacement: step 12, image 1 of 1
      • Lift out the top right ribbon from its slot on the motherboard.
      Ask FixBot
    4. Samsung Instinct Front Case Replacement: step 13, image 1 of 2 Samsung Instinct Front Case Replacement: step 13, image 2 of 2
      • Use the plastic opener tool to unhinge the the locks on the side of the motherboard connecting it to the front casing.
      Ask FixBot
    5. Samsung Instinct Front Case Replacement: step 14, image 1 of 1
      • Lift the motherboard away from the front casing.
      Ask FixBot
    6. Samsung Instinct Front Case Replacement: step 15, image 1 of 1
      • After removing lifting up on the motherboard, the front casing and center frame should be separated as shown.
      Ask FixBot
Author
with
Jacob Michener
31 Reputation
2 Guides authored
Cal Poly, Team 3-13, Regan Fall 2011 Member of Cal Poly, Team 3-13, Regan Fall 2011
CPSU-REGAN-F11S3G13
4 Members
96 Guides authored
0 Guide Comments
Past 24 Hours: 0
Past 7 Days: 3
Past 30 Days: 17
All Time: 1,139
