Up to 20% off select tools
Samsung Instinct Antenna Replacement
Views: 1.4K
View statistics:
Past 24 Hours:
Past 7 Days:
Past 30 Days:
16
All Time:
1,440
Comments: 0
Go to guide comments
Completed: 0
Favorites: 0
Time Required: 5 minutes
Difficulty: Moderate
Tools
Introduction
Go to step 1 ↓
This guide shows how to take out the antenna so that a replacement can be installed.
    1. Samsung Instinct Antenna Replacement, Battery: step 1, image 1 of 1
      • Apply pressure to the back cover and slide it forward towards the camera.
      • Lift the back cover off the phone.
      Ask FixBot
    2. Samsung Instinct Antenna Replacement: step 2, image 1 of 1
      • Holding the phone firmly, use the notches to grip and lift up the battery.
      Ask FixBot
    1. Samsung Instinct Antenna Replacement, Back Case: step 3, image 1 of 1
      • Remove the four 4.45mm screws at the corners of the phone.
      Ask FixBot
    2. Samsung Instinct Antenna Replacement: step 4, image 1 of 2 Samsung Instinct Antenna Replacement: step 4, image 2 of 2
      • Use the plastic opening tool to unhinge the locks around the edges of the phone.
      • Do not worry about the inner components of the phone; they are not connected to this case.
      Ask FixBot
    3. Samsung Instinct Antenna Replacement: step 5, image 1 of 1
      • Lift the casing off of the phone.
      Ask FixBot
    1. Samsung Instinct Antenna Replacement, Antenna: step 6, image 1 of 1
      • With the screws removed, locate the antenna.
      Ask FixBot
    2. Samsung Instinct Antenna Replacement: step 7, image 1 of 1
      • Using a Phillips head screwdriver, remove the 4.50mm screw holding the antenna in place.
      Ask FixBot
    3. Samsung Instinct Antenna Replacement: step 8, image 1 of 1
      • Using the plastic opener tool, squeeze gently on the antenna cable connector and lift to remove the connector from its position.
      Ask FixBot
    4. Samsung Instinct Antenna Replacement: step 9, image 1 of 1
      • Gently lift up on the antenna and remove it from the back of the device.
      Ask FixBot
Author
with
Jimmy Kuo
14 Reputation
2 Guides authored
Cal Poly, Team 3-13, Regan Fall 2011 Member of Cal Poly, Team 3-13, Regan Fall 2011
CPSU-REGAN-F11S3G13
4 Members
96 Guides authored
0 Guide Comments
Past 24 Hours: 1
Past 7 Days: 1
Past 30 Days: 16
All Time: 1,440
