Samsung Impression LCD Flex Cable Replacement
    1. Samsung Impression LCD Flex Cable Replacement, Battery: step 1, image 1 of 1
      • Orient the phone with the screen facing downward.
      • Slide the panel away from the camera using your thumb. This will expose the battery.
      Ask FixBot
    2. Samsung Impression LCD Flex Cable Replacement: step 2, image 1 of 2 Samsung Impression LCD Flex Cable Replacement: step 2, image 2 of 2
      • Insert the tip of the spudger on the left side of the battery.
      • Pry the battery out. It will pivot in the direction of the white arrow.
      Ask FixBot
    1. Samsung Impression LCD Flex Cable Replacement, Back Cover: step 3, image 1 of 1
      • Remove the six 3.5 mm screws using a Phillips #000 screwdriver. Unscrew in a counterclockwise direction.
      Ask FixBot
    2. Samsung Impression LCD Flex Cable Replacement: step 4, image 1 of 1
      • Gently pry around the edges with the spudger to remove back panel.
      • It may help to slide the touchscreen upwards when removing the back panel.
      • The side buttons will become loose and will fall out, so put these in a safe place.
      Ask FixBot
    1. Samsung Impression LCD Flex Cable Replacement, Circuit Board: step 5, image 1 of 1
      • Gently remove the black wire to free the circuit board.
      • Remove the wire by gently prying up the gold terminator attached to the green circuit board.
      Ask FixBot
    2. Samsung Impression LCD Flex Cable Replacement: step 6, image 1 of 2 Samsung Impression LCD Flex Cable Replacement: step 6, image 2 of 2
      • Gently tug the black and blue ribbon upwards to release the circuit board.
      Ask FixBot
    1. Samsung Impression LCD Flex Cable Replacement, Keyboard: step 7, image 1 of 1
      • Remove the two base screws along the edge of the silver piece, where you just removed the black end piece.
      • The screws are 2.7mm in length.
      • The bottom black end cap will snap out.
      Ask FixBot
    2. Samsung Impression LCD Flex Cable Replacement: step 8, image 1 of 2 Samsung Impression LCD Flex Cable Replacement: step 8, image 2 of 2
      • Remove the six 2.7 mm screws holding the silver plate on and set aside (fig. 1).
      • Separate the silver plate and phone frame (fig. 2).
      Ask FixBot
    3. Samsung Impression LCD Flex Cable Replacement: step 9, image 1 of 1
      • The silver piece you are left with is the physical keyboard assembly.
      Ask FixBot
    1. Samsung Impression LCD Flex Cable Replacement, LCD Flex Cable: step 10, image 1 of 2 Samsung Impression LCD Flex Cable Replacement, LCD Flex Cable: step 10, image 2 of 2
      • Remove the 3 screws holding down the flex cable.
      • The two screws on the black frame are 2.0 mm in length.
      • The top right screw that goes through the circle port on the flex cable is 2.3 mm.
      • Remove the keyboard slider frame. The flex cable should be exposed, but not free.
      Ask FixBot
    2. Samsung Impression LCD Flex Cable Replacement: step 11, image 1 of 1
      • Remove the four 3.5 mm outer screws.
      Ask FixBot
    3. Samsung Impression LCD Flex Cable Replacement: step 12, image 1 of 3 Samsung Impression LCD Flex Cable Replacement: step 12, image 2 of 3 Samsung Impression LCD Flex Cable Replacement: step 12, image 3 of 3
      • Slide the phone apart and remove the 3.5 mm screw on the top middle (fig. 1).
      • Remove the outer shell by prying the edges off with your fingers or a small screwdriver (fig. 2).
      • The device will now be in two pieces (fig. 3).
      Ask FixBot
    4. Samsung Impression LCD Flex Cable Replacement: step 13, image 1 of 2 Samsung Impression LCD Flex Cable Replacement: step 13, image 2 of 2
      • Lift the tab underneath the blue tape and gently pull the flex cable (fig. 1).
      • The flex cable will now be completely free (fig. 2).
      Ask FixBot
2 other people completed this guide.
Saul Villatoro
260 Reputation
7 Guides authored
Cal Poly, Team 8-10, Regan Spring 2011 Member of Cal Poly, Team 8-10, Regan Spring 2011
CPSU-REGAN-S11S8G10
4 Members
132 Guides authored
0 Guide Comments
Past 24 Hours: 0
Past 7 Days: 3
Past 30 Days: 48
All Time: 7,936
