Up to 20% off select tools
Samsung Impression Keyboard Replacement
Views: 3K
View statistics:
Past 24 Hours:
2
Past 7 Days:
13
Past 30 Days:
85
All Time:
3,008
Comments: 0
Go to guide comments
Completed: 0
Favorites: 2
2 people have favorited (and subscribed to) this guide. Will you be next?
Time Required: 20 minutes
Difficulty: Moderate
Action Shots
Be an action hero! This guide needs images that better demonstrate how to perform specific actions.
Needs Better Images
Better photos will improve this guide. Help out by taking, editing, or uploading new ones!
Better Introduction
Improve this guide by completing or revising its introduction.
Tools
Introduction
Go to step 1 ↓
How to remove & replace the phone's keyboard.
    1. Samsung Impression Keyboard Replacement, Battery: step 1, image 1 of 1
      • Orient the phone with the screen facing downward.
      • Slide the panel away from the camera using your thumb. This will expose the battery.
      Ask FixBot
    2. Samsung Impression Keyboard Replacement: step 2, image 1 of 2 Samsung Impression Keyboard Replacement: step 2, image 2 of 2
      • Insert the tip of the spudger on the left side of the battery.
      • Pry the battery out. It will pivot in the direction of the white arrow.
      Ask FixBot
    1. Samsung Impression Keyboard Replacement, Back Cover: step 3, image 1 of 1
      • Remove the six 3.5 mm screws using a Phillips #000 screwdriver. Unscrew in a counterclockwise direction.
      Ask FixBot
    2. Samsung Impression Keyboard Replacement: step 4, image 1 of 1
      • Gently pry around the edges with the spudger to remove back panel.
      • It may help to slide the touchscreen upwards when removing the back panel.
      • The side buttons will become loose and will fall out, so put these in a safe place.
      Ask FixBot
    1. Samsung Impression Keyboard Replacement, Circuit Board: step 5, image 1 of 1
      • Gently remove the black wire to free the circuit board.
      • Remove the wire by gently prying up the gold terminator attached to the green circuit board.
      Ask FixBot
    2. Samsung Impression Keyboard Replacement: step 6, image 1 of 2 Samsung Impression Keyboard Replacement: step 6, image 2 of 2
      • Gently tug the black and blue ribbon upwards to release the circuit board.
      Ask FixBot
    1. Samsung Impression Keyboard Replacement, Antenna: step 7, image 1 of 2 Samsung Impression Keyboard Replacement, Antenna: step 7, image 2 of 2
      • Use a Phillips screwdriver to remove the six 3.5 mm screws by rotating.
      • The antenna assembly will snap off.
      Ask FixBot
    1. Samsung Impression Keyboard Replacement, Keyboard: step 8, image 1 of 1
      • Remove the two base screws along the edge of the silver piece, where you just removed the black end piece.
      • The screws are 2.7mm in length.
      • The bottom black end cap will snap out.
      Ask FixBot
    2. Samsung Impression Keyboard Replacement: step 9, image 1 of 2 Samsung Impression Keyboard Replacement: step 9, image 2 of 2
      • Remove the six 2.7 mm screws holding the silver plate on and set aside (fig. 1).
      • Separate the silver plate and phone frame (fig. 2).
      Ask FixBot
    3. Samsung Impression Keyboard Replacement: step 10, image 1 of 1
      • The silver piece you are left with is the physical keyboard assembly.
      Ask FixBot
Author
with
Ross McKelvie
196 Reputation
4 Guides authored
Cal Poly, Team 8-10, Regan Spring 2011 Member of Cal Poly, Team 8-10, Regan Spring 2011
CPSU-REGAN-S11S8G10
4 Members
132 Guides authored
0 Guide Comments
Past 24 Hours: 2
Past 7 Days: 13
Past 30 Days: 85
All Time: 3,008
