Samsung Impression Digitizer or Front Buttons Replacement
Views: 7.4K
View statistics:
Past 24 Hours:
2
Past 7 Days:
17
Past 30 Days:
99
All Time:
7,448
Comments: 0
Go to guide comments
Completed: 3
3 people have marked this guide "completed." Will you be next?
Favorites: 5
5 people have favorited (and subscribed to) this guide. Will you be next?
Time Required: 5 minutes
Difficulty: Moderate
Action Shots
Be an action hero! This guide needs images that better demonstrate how to perform specific actions.
Needs Better Images
Better photos will improve this guide. Help out by taking, editing, or uploading new ones!
Markup Mishap
This guide needs better markups. Help out by correcting or making some markup annotations.
Better Introduction
Improve this guide by completing or revising its introduction.
Introduction
Go to step 1 ↓
How to remove & replace the phone's digitizer or front buttons
Tools
    1. Samsung Impression Digitizer or Front Buttons Replacement, Battery: step 1, image 1 of 1
      • Orient the phone with the screen facing downward.
      • Slide the panel away from the camera using your thumb. This will expose the battery.
      Ask FixBot
    2. Samsung Impression Digitizer or Front Buttons Replacement: step 2, image 1 of 2 Samsung Impression Digitizer or Front Buttons Replacement: step 2, image 2 of 2
      • Insert the tip of the spudger on the left side of the battery.
      • Pry the battery out. It will pivot in the direction of the white arrow.
      Ask FixBot
    1. Samsung Impression Digitizer or Front Buttons Replacement, Back Cover: step 3, image 1 of 1
      • Remove the six 3.5 mm screws using a Phillips #000 screwdriver. Unscrew in a counterclockwise direction.
      Ask FixBot
    2. Samsung Impression Digitizer or Front Buttons Replacement: step 4, image 1 of 1
      • Gently pry around the edges with the spudger to remove back panel.
      • It may help to slide the touchscreen upwards when removing the back panel.
      • The side buttons will become loose and will fall out, so put these in a safe place.
      Ask FixBot
    1. Samsung Impression Digitizer or Front Buttons Replacement, Circuit Board: step 5, image 1 of 1
      • Gently remove the black wire to free the circuit board.
      • Remove the wire by gently prying up the gold terminator attached to the green circuit board.
      Ask FixBot
    2. Samsung Impression Digitizer or Front Buttons Replacement: step 6, image 1 of 2 Samsung Impression Digitizer or Front Buttons Replacement: step 6, image 2 of 2
      • Gently tug the black and blue ribbon upwards to release the circuit board.
      Ask FixBot
    1. Samsung Impression Digitizer or Front Buttons Replacement, Keyboard: step 7, image 1 of 1
      • Remove the two base screws along the edge of the silver piece, where you just removed the black end piece.
      • The screws are 2.7mm in length.
      • The bottom black end cap will snap out.
      Ask FixBot
    2. Samsung Impression Digitizer or Front Buttons Replacement: step 8, image 1 of 2 Samsung Impression Digitizer or Front Buttons Replacement: step 8, image 2 of 2
      • Remove the six 2.7 mm screws holding the silver plate on and set aside (fig. 1).
      • Separate the silver plate and phone frame (fig. 2).
      Ask FixBot
    3. Samsung Impression Digitizer or Front Buttons Replacement: step 9, image 1 of 1
      • The silver piece you are left with is the physical keyboard assembly.
      Ask FixBot
    1. Samsung Impression Digitizer or Front Buttons Replacement, LCD Flex Cable: step 10, image 1 of 2 Samsung Impression Digitizer or Front Buttons Replacement, LCD Flex Cable: step 10, image 2 of 2
      • Remove the 3 screws holding down the flex cable.
      • The two screws on the black frame are 2.0 mm in length.
      • The top right screw that goes through the circle port on the flex cable is 2.3 mm.
      • Remove the keyboard slider frame. The flex cable should be exposed, but not free.
      Ask FixBot
    2. Samsung Impression Digitizer or Front Buttons Replacement: step 11, image 1 of 1
      • Remove the four 3.5 mm outer screws.
      Ask FixBot
    3. Samsung Impression Digitizer or Front Buttons Replacement: step 12, image 1 of 3 Samsung Impression Digitizer or Front Buttons Replacement: step 12, image 2 of 3 Samsung Impression Digitizer or Front Buttons Replacement: step 12, image 3 of 3
      • Slide the phone apart and remove the 3.5 mm screw on the top middle (fig. 1).
      • Remove the outer shell by prying the edges off with your fingers or a small screwdriver (fig. 2).
      • The device will now be in two pieces (fig. 3).
      Ask FixBot
    4. Samsung Impression Digitizer or Front Buttons Replacement: step 13, image 1 of 2 Samsung Impression Digitizer or Front Buttons Replacement: step 13, image 2 of 2
      • Lift the tab underneath the blue tape and gently pull the flex cable (fig. 1).
      • The flex cable will now be completely free (fig. 2).
      Ask FixBot
    1. Samsung Impression Digitizer or Front Buttons Replacement, Ear Speaker: step 14, image 1 of 1
      • Remove the 2.3 mm screw.
      • Lift the black tab at the end of the ribbon.
      • Gently pull the speaker and ribbon free.
      Ask FixBot
    1. Samsung Impression Digitizer or Front Buttons Replacement, LCD: step 15, image 1 of 2 Samsung Impression Digitizer or Front Buttons Replacement, LCD: step 15, image 2 of 2
      • Lift the remaining two tabs and free their respective ribbon cables.
      • Gently pry the screen away from the housing.
      • Be careful with this step as you are in direct contact with the LCD screen.
      Ask FixBot
    1. Samsung Impression Digitizer or Front Buttons Replacement, Digitizer or Front Buttons: step 16, image 1 of 1
      • If replacing the front buttons, remove the assembly at the bottom of the front panel
      • The digitizer is now free to be pulled out from the front housing.
      Ask FixBot
3 other people completed this guide.
Saul Villatoro
260 Reputation
7 Guides authored
Cal Poly, Team 8-10, Regan Spring 2011 Member of Cal Poly, Team 8-10, Regan Spring 2011
CPSU-REGAN-S11S8G10
4 Members
132 Guides authored
0 Guide Comments
Past 24 Hours: 2
Past 7 Days: 17
Past 30 Days: 99
All Time: 7,448
