Samsung Impression Circuit Board Replacement
Views: 4.4K
View statistics:
Past 24 Hours:
2
Past 7 Days:
20
Past 30 Days:
84
All Time:
4,433
Comments: 0
Go to guide comments
Completed: 0
Favorites: 2
2 people have favorited (and subscribed to) this guide. Will you be next?
Time Required: 15 minutes
Difficulty: Moderate
Action Shots
Be an action hero! This guide needs images that better demonstrate how to perform specific actions.
Needs Better Images
Better photos will improve this guide. Help out by taking, editing, or uploading new ones!
Introduction
Go to step 1 ↓
Has your Samsung Impression smartphone stopped working after countless fixes? Is the battery still functional, but the phone cannot boot up?
You may have a shorted circuit board. The circuit board of the Samsung Impression contains all systems necessary to make the cell phone function: memory, CPU, radio antennas, and oscillators.
Well don't retire your cellphone just yet! A circuit board replacement can help you save money and keep your phone. This step-by-step guide will help you easily remove and replace your phone's circuit board within 15 minutes.
Prior to reading these instructions, purchase a circuit board from the official Samsung parts website at https://www.samsungparts.com/Default.asp.... Once you've received the new circuit board, power off the Samsung Impression and carefully follow these step-by-step instructions for replacing the circuit board with the necessary tools listed below.
Tools
  • Phillips #0 Screwdriver
    5
  • Spudger
    4.9
    1. Samsung Impression Circuit Board Replacement, Battery: step 1, image 1 of 1
      • Orient the phone with the screen facing downward.
      • Slide the panel away from the camera using your thumb. This will expose the battery.
      Ask FixBot
    2. Samsung Impression Circuit Board Replacement: step 2, image 1 of 2 Samsung Impression Circuit Board Replacement: step 2, image 2 of 2
      • Insert the tip of the spudger on the left side of the battery.
      • Pry the battery out. It will pivot in the direction of the white arrow.
      Ask FixBot
    1. Samsung Impression Circuit Board Replacement, Back Cover: step 3, image 1 of 1
      • Remove the six 3.5 mm screws using a Phillips #000 screwdriver. Unscrew in a counterclockwise direction.
      Ask FixBot
    2. Samsung Impression Circuit Board Replacement: step 4, image 1 of 1
      • Gently pry around the edges with the spudger to remove back panel.
      • It may help to slide the touchscreen upwards when removing the back panel.
      • The side buttons will become loose and will fall out, so put these in a safe place.
      Ask FixBot
    1. Samsung Impression Circuit Board Replacement, Back Speaker: step 5, image 1 of 1
      • Carefully pry the back speaker upwards with a spudger.
      • The speaker is still connected to the circuit board by a wire and small piece of clear plastic.
      • Disconnect the speaker by lifting the clear plastic piece attached to the wire.
      Ask FixBot
    1. Samsung Impression Circuit Board Replacement, Circuit Board: step 6, image 1 of 1
      • Gently remove the black wire to free the circuit board.
      • Remove the wire by gently prying up the gold terminator attached to the green circuit board.
      Ask FixBot
    2. Samsung Impression Circuit Board Replacement: step 7, image 1 of 2 Samsung Impression Circuit Board Replacement: step 7, image 2 of 2
      • Gently tug the black and blue ribbon upwards to release the circuit board.
      Ask FixBot
To reassemble the device, carefully follow these instructions in reverse order. With a new circuit board installed, your phone should be functional again! For more guides on Samsung Impression maintenance, visit www.ifixit.com.
Ross McKelvie
196 Reputation
4 Guides authored
Cal Poly, Team 8-10, Regan Spring 2011 Member of Cal Poly, Team 8-10, Regan Spring 2011
CPSU-REGAN-S11S8G10
4 Members
132 Guides authored
0 Guide Comments
Past 24 Hours: 2
Past 7 Days: 20
Past 30 Days: 84
All Time: 4,433
