Up to 20% off select tools
Samsung Impression Antenna Replacement
Views: 3.6K
View statistics:
Past 24 Hours:
3
Past 7 Days:
16
Past 30 Days:
107
All Time:
3,645
Comments: 0
Go to guide comments
Completed: 1
1 person has marked this guide "completed." Will you be next?
Favorites: 1
1 person has favorited (and subscribed to) this guide. Will you be next?
Time Required: 35 - 55 minutes
Difficulty: Moderate
Action Shots
Be an action hero! This guide needs images that better demonstrate how to perform specific actions.
Needs Better Images
Better photos will improve this guide. Help out by taking, editing, or uploading new ones!
Tools
  • Spudger
    4.9
  • Phillips #0 Screwdriver
    5
Introduction
Go to step 1 ↓
Replacing the Wi-Fi card may be necessary if your Samsung Impression experiences slow or unstable internet connections. This guide will show you how to remove and install a new Wi-Fi card to restore proper functionality.
Before beginning, power off the device and disconnect the battery to prevent electrical damage. This repair involves handling small internal components. Use caution when working inside the device, as cables and connectors are fragile and can be easily damaged.
    1. Samsung Impression Antenna Replacement, Battery: step 1, image 1 of 1
      • Orient the phone with the screen facing downward.
      • Slide the panel away from the camera using your thumb. This will expose the battery.
      Ask FixBot
    2. Samsung Impression Antenna Replacement: step 2, image 1 of 2 Samsung Impression Antenna Replacement: step 2, image 2 of 2
      • Insert the tip of the spudger on the left side of the battery.
      • Pry the battery out. It will pivot in the direction of the white arrow.
      Ask FixBot
    1. Samsung Impression Antenna Replacement, Back Cover: step 3, image 1 of 1
      • Remove the six 3.5 mm screws using a Phillips #000 screwdriver. Unscrew in a counterclockwise direction.
      Ask FixBot
    2. Samsung Impression Antenna Replacement: step 4, image 1 of 1
      • Gently pry around the edges with the spudger to remove back panel.
      • It may help to slide the touchscreen upwards when removing the back panel.
      • The side buttons will become loose and will fall out, so put these in a safe place.
      Ask FixBot
    1. Samsung Impression Antenna Replacement, Circuit Board: step 5, image 1 of 1
      • Gently remove the black wire to free the circuit board.
      • Remove the wire by gently prying up the gold terminator attached to the green circuit board.
      Ask FixBot
    2. Samsung Impression Antenna Replacement: step 6, image 1 of 2 Samsung Impression Antenna Replacement: step 6, image 2 of 2
      • Gently tug the black and blue ribbon upwards to release the circuit board.
      Ask FixBot
    1. Samsung Impression Antenna Replacement, Antenna: step 7, image 1 of 2 Samsung Impression Antenna Replacement, Antenna: step 7, image 2 of 2
      • Use a Phillips screwdriver to remove the six 3.5 mm screws by rotating.
      • The antenna assembly will snap off.
      Ask FixBot
To replace the antenna and reassemble your device, follow the steps in reverse order. Take your e-waste to an R2 or e-Stewards certified recycler.
Author
with
Saul Villatoro
260 Reputation
7 Guides authored
Cal Poly, Team 8-10, Regan Spring 2011 Member of Cal Poly, Team 8-10, Regan Spring 2011
CPSU-REGAN-S11S8G10
4 Members
132 Guides authored
0 Guide Comments
Past 24 Hours: 3
Past 7 Days: 16
Past 30 Days: 107
All Time: 3,645
