Samsung HMX-W300 Battery Replacement
    1. Samsung HMX-W300 Battery Replacement, Disassembling Samsung HMX-W300: step 1, image 1 of 3 Samsung HMX-W300 Battery Replacement, Disassembling Samsung HMX-W300: step 1, image 2 of 3 Samsung HMX-W300 Battery Replacement, Disassembling Samsung HMX-W300: step 1, image 3 of 3
      • To remove the wristband of the device, grab the middle loop and pull the band through.
      Ask FixBot
    2. Samsung HMX-W300 Battery Replacement: step 2, image 1 of 2 Samsung HMX-W300 Battery Replacement: step 2, image 2 of 2
      • Remove four screws with a Hex 1.5 mm screwdriver.
      Ask FixBot
    3. Samsung HMX-W300 Battery Replacement: step 3, image 1 of 3 Samsung HMX-W300 Battery Replacement: step 3, image 2 of 3 Samsung HMX-W300 Battery Replacement: step 3, image 3 of 3
      • Open the HDMI door on the side of the camera.
      • Remove the single screw using a Phillips #00 screwdriver.
      Ask FixBot
    4. Samsung HMX-W300 Battery Replacement: step 4, image 1 of 3 Samsung HMX-W300 Battery Replacement: step 4, image 2 of 3 Samsung HMX-W300 Battery Replacement: step 4, image 3 of 3
      • Use the iFixit opening tool on both sides on the device. Pry apart both sections with light force.
      • Do not apply too much force. There is a wire that attaches the front case with the rear case that can be damaged.
      Ask FixBot
    5. Samsung HMX-W300 Battery Replacement: step 5, image 1 of 3 Samsung HMX-W300 Battery Replacement: step 5, image 2 of 3 Samsung HMX-W300 Battery Replacement: step 5, image 3 of 3
      Tool used on this step:
      Buy
      • Pull the wire ribbon out with a pair of tweezers.
      Ask FixBot
    1. Samsung HMX-W300 Battery Replacement, Battery: step 6, image 1 of 2 Samsung HMX-W300 Battery Replacement, Battery: step 6, image 2 of 2
      • Remove the four screws from the battery housing using a Phillips #00 screwdriver.
      Ask FixBot
    2. Samsung HMX-W300 Battery Replacement: step 7, image 1 of 1
      • Use the iFixit opening tool to pry the battery housing open.
      Ask FixBot
    3. Samsung HMX-W300 Battery Replacement: step 8, image 1 of 3 Samsung HMX-W300 Battery Replacement: step 8, image 2 of 3 Samsung HMX-W300 Battery Replacement: step 8, image 3 of 3
      • After removing the battery housing, take the battery out.
      Ask FixBot
6 other people completed this guide.
Robert
966 Reputation
8 Guides authored
USF Tampa, Team 9-2, Blackwell Winter 2015 Member of USF Tampa, Team 9-2, Blackwell Winter 2015
USFT-BLACKWELL-W15S9G2
4 Members
96 Guides authored
2 Guide Comments
What type of battery is this? What part number should we use to order a replacement?
VanDemark - Reply Share
The type of battery should be printed on the case of the battery. Most likely it’s some type of lithium battery. The part number for the battery should be on the case as well. If you can’t find either of these on the battery case you can take the battery to a place that sales batteries and the personnel there should be able to tell you the type and part number for your battery.
Jarretti Reaves - Reply Share
Past 24 Hours: 2
Past 7 Days: 6
Past 30 Days: 32
All Time: 2,809
