Samsung HMX-W200 Speaker Replacement
  1. Samsung HMX-W200 Speaker Replacement, Outer Case: step 1, image 1 of 1
    • Remove the 5.00mm screw on the right of the LCD display towards the bottom of the device by using a Phillips #00 screwdriver.
  2. Samsung HMX-W200 Speaker Replacement: step 2, image 1 of 3 Samsung HMX-W200 Speaker Replacement: step 2, image 2 of 3 Samsung HMX-W200 Speaker Replacement: step 2, image 3 of 3
    • Use the plastic opening tool to separate and remove the bottom red casing. Do this by, pushing the tool into the seam and prying up the red casing as you move along the edges.
    • Make sure to separate all the corners before removing the red casing.
  3. Samsung HMX-W200 Speaker Replacement: step 3, image 1 of 2 Samsung HMX-W200 Speaker Replacement: step 3, image 2 of 2
    • Using the plastic opening tool, separate and pull away the red casing on the right of the LCD screen.
  4. Samsung HMX-W200 Speaker Replacement: step 4, image 1 of 2 Samsung HMX-W200 Speaker Replacement: step 4, image 2 of 2
    • To access the HDMI slot, move slider towards the bottom of the casing on the other side of the camcorder. The lid casing will lift up upon doing so.
    • After accessing the HDMI slot you will find a 5.00mm screw. Using a Phillips #00 screwdriver, remove the screw.
  5. Samsung HMX-W200 Speaker Replacement: step 5, image 1 of 2 Samsung HMX-W200 Speaker Replacement: step 5, image 2 of 2
    • Using the plastic opening tool, separate and pull away the red casing to the left of the LCD screen.
  6. Samsung HMX-W200 Speaker Replacement: step 6, image 1 of 2 Samsung HMX-W200 Speaker Replacement: step 6, image 2 of 2
    • Remove the six 5.00mm screws by using a Phillips #00 screwdriver.
  7. Samsung HMX-W200 Speaker Replacement: step 7, image 1 of 3 Samsung HMX-W200 Speaker Replacement: step 7, image 2 of 3 Samsung HMX-W200 Speaker Replacement: step 7, image 3 of 3
    • Lift the two plastic tabs on the left side of the LCD screen and the single one on the right side on the black casing to open the device.
  8. Samsung HMX-W200 Speaker Replacement: step 8, image 1 of 1
    • Separate the front and back casing.
  9. Samsung HMX-W200 Speaker Replacement, Motherboard: step 9, image 1 of 1
    • Once inside the device, find the half that contains the motherboard of the device.
  10. Samsung HMX-W200 Speaker Replacement: step 10, image 1 of 1
    Tool used on this step:
    Buy
    • Use precision tweezers to gently pull out the USB connection from the motherboard.
  11. Samsung HMX-W200 Speaker Replacement: step 11, image 1 of 2 Samsung HMX-W200 Speaker Replacement: step 11, image 2 of 2
    • Remove the audio connector from the motherboard (red and black cables).
    • Using the plastic opening tool, lift the connectors from all sides before pulling it with your fingers.
    • Do not pull off the connectors by the cables. This could damage the connection from the speaker to the motherboard.
  12. Samsung HMX-W200 Speaker Replacement: step 12, image 1 of 2 Samsung HMX-W200 Speaker Replacement: step 12, image 2 of 2
    • Use precision tweezers to remove the connector joining the LCD and the motherboard.
  13. Samsung HMX-W200 Speaker Replacement: step 13, image 1 of 2 Samsung HMX-W200 Speaker Replacement: step 13, image 2 of 2
    • Remove the six 2.00mm screws with Phillips #00 screwdriver.
  14. Samsung HMX-W200 Speaker Replacement: step 14, image 1 of 3 Samsung HMX-W200 Speaker Replacement: step 14, image 2 of 3 Samsung HMX-W200 Speaker Replacement: step 14, image 3 of 3
    • Lift motherboard from top left side and pull away gently.
  15. Samsung HMX-W200 Speaker Replacement, Speaker: step 15, image 1 of 2 Samsung HMX-W200 Speaker Replacement, Speaker: step 15, image 2 of 2
    • Under the motherboard there is a metal plate that has to be removed.
    • Use a Phillips head #00 screwdriver to remove eleven 5mm screws.
  16. Samsung HMX-W200 Speaker Replacement: step 16, image 1 of 2 Samsung HMX-W200 Speaker Replacement: step 16, image 2 of 2
    • Lift the metal plate by pushing it up from the top right edge of the plate.
  17. Samsung HMX-W200 Speaker Replacement: step 17, image 1 of 3 Samsung HMX-W200 Speaker Replacement: step 17, image 2 of 3 Samsung HMX-W200 Speaker Replacement: step 17, image 3 of 3
    Buy
    • Use precision tweezers to remove the speaker from the casing.
    • It will be a bit difficult because the speaker is glued to the casing.
    • Be sure to only pull the speaker and not the white screen under it. This screen is what allows the speaker to be waterproof and if it gets damaged, the device will no longer be waterproof.
Haya Barakat
542 Reputation
5 Guides authored
USF Tampa, Team 3-6, Sullivan Fall 2016 Member of USF Tampa, Team 3-6, Sullivan Fall 2016
USFT-SULLIVAN-F16S3G6
4 Members
13 Guides authored
0 Guide Comments
Past 24 Hours: 1
Past 7 Days: 6
Past 30 Days: 31
All Time: 353
