Samsung HMX-W200 LCD Screen Replacement
    1. Samsung HMX-W200 LCD Screen Replacement, Outer Case: step 1, image 1 of 1
      • Remove the 5.00mm screw on the right of the LCD display towards the bottom of the device by using a Phillips #00 screwdriver.
      Ask FixBot
    2. Samsung HMX-W200 LCD Screen Replacement: step 2, image 1 of 3 Samsung HMX-W200 LCD Screen Replacement: step 2, image 2 of 3 Samsung HMX-W200 LCD Screen Replacement: step 2, image 3 of 3
      • Use the plastic opening tool to separate and remove the bottom red casing. Do this by, pushing the tool into the seam and prying up the red casing as you move along the edges.
      • Make sure to separate all the corners before removing the red casing.
      Ask FixBot
    3. Samsung HMX-W200 LCD Screen Replacement: step 3, image 1 of 2 Samsung HMX-W200 LCD Screen Replacement: step 3, image 2 of 2
      • Using the plastic opening tool, separate and pull away the red casing on the right of the LCD screen.
      Ask FixBot
    4. Samsung HMX-W200 LCD Screen Replacement: step 4, image 1 of 2 Samsung HMX-W200 LCD Screen Replacement: step 4, image 2 of 2
      • To access the HDMI slot, move slider towards the bottom of the casing on the other side of the camcorder. The lid casing will lift up upon doing so.
      • After accessing the HDMI slot you will find a 5.00mm screw. Using a Phillips #00 screwdriver, remove the screw.
      Ask FixBot
    5. Samsung HMX-W200 LCD Screen Replacement: step 5, image 1 of 2 Samsung HMX-W200 LCD Screen Replacement: step 5, image 2 of 2
      • Using the plastic opening tool, separate and pull away the red casing to the left of the LCD screen.
      Ask FixBot
    6. Samsung HMX-W200 LCD Screen Replacement: step 6, image 1 of 2 Samsung HMX-W200 LCD Screen Replacement: step 6, image 2 of 2
      • Remove the six 5.00mm screws by using a Phillips #00 screwdriver.
      Ask FixBot
    7. Samsung HMX-W200 LCD Screen Replacement: step 7, image 1 of 3 Samsung HMX-W200 LCD Screen Replacement: step 7, image 2 of 3 Samsung HMX-W200 LCD Screen Replacement: step 7, image 3 of 3
      • Lift the two plastic tabs on the left side of the LCD screen and the single one on the right side on the black casing to open the device.
      Ask FixBot
    8. Samsung HMX-W200 LCD Screen Replacement: step 8, image 1 of 1
      • Separate the front and back casing.
      Ask FixBot
    1. Samsung HMX-W200 LCD Screen Replacement, Motherboard: step 9, image 1 of 1
      • Once inside the device, find the half that contains the motherboard of the device.
      Ask FixBot
    2. Samsung HMX-W200 LCD Screen Replacement: step 10, image 1 of 1
      Tool used on this step:
      Buy
      • Use precision tweezers to gently pull out the USB connection from the motherboard.
      Ask FixBot
    3. Samsung HMX-W200 LCD Screen Replacement: step 11, image 1 of 2 Samsung HMX-W200 LCD Screen Replacement: step 11, image 2 of 2
      • Remove the audio connector from the motherboard (red and black cables).
      • Using the plastic opening tool, lift the connectors from all sides before pulling it with your fingers.
      • Do not pull off the connectors by the cables. This could damage the connection from the speaker to the motherboard.
      Ask FixBot
    4. Samsung HMX-W200 LCD Screen Replacement: step 12, image 1 of 2 Samsung HMX-W200 LCD Screen Replacement: step 12, image 2 of 2
      • Use precision tweezers to remove the connector joining the LCD and the motherboard.
      Ask FixBot
    5. Samsung HMX-W200 LCD Screen Replacement: step 13, image 1 of 2 Samsung HMX-W200 LCD Screen Replacement: step 13, image 2 of 2
      • Remove the six 2.00mm screws with Phillips #00 screwdriver.
      Ask FixBot
    6. Samsung HMX-W200 LCD Screen Replacement: step 14, image 1 of 3 Samsung HMX-W200 LCD Screen Replacement: step 14, image 2 of 3 Samsung HMX-W200 LCD Screen Replacement: step 14, image 3 of 3
      • Lift motherboard from top left side and pull away gently.
      Ask FixBot
    1. Samsung HMX-W200 LCD Screen Replacement, LCD Screen: step 15, image 1 of 2 Samsung HMX-W200 LCD Screen Replacement, LCD Screen: step 15, image 2 of 2
      • Remove the metal plate under the motherboard.
      • Use a Phillips head #00 screwdriver to remove the eleven 5.00mm screws.
      Ask FixBot
    2. Samsung HMX-W200 LCD Screen Replacement: step 16, image 1 of 2 Samsung HMX-W200 LCD Screen Replacement: step 16, image 2 of 2
      • Lift the metal plate by pushing it up from the top right edge of the plate.
      Ask FixBot
    3. Samsung HMX-W200 LCD Screen Replacement: step 17, image 1 of 2 Samsung HMX-W200 LCD Screen Replacement: step 17, image 2 of 2
      • Insert spudger in between the LCD and casing, and push lightly.
      • LCD should pop up.
      Ask FixBot
Haya Barakat
542 Reputation
5 Guides authored
USF Tampa, Team 3-6, Sullivan Fall 2016 Member of USF Tampa, Team 3-6, Sullivan Fall 2016
USFT-SULLIVAN-F16S3G6
4 Members
84 Guides authored
0 Guide Comments
Past 24 Hours: 0
Past 7 Days: 3
Past 30 Days: 19
All Time: 736
