Samsung HMX-W200 Battery Replacement
    1. Samsung HMX-W200 Battery Replacement, Outer Case: step 1, image 1 of 1
      • Remove the 5.00mm screw on the right of the LCD display towards the bottom of the device by using a Phillips #00 screwdriver.
      Ask FixBot
    2. Samsung HMX-W200 Battery Replacement: step 2, image 1 of 3 Samsung HMX-W200 Battery Replacement: step 2, image 2 of 3 Samsung HMX-W200 Battery Replacement: step 2, image 3 of 3
      • Use the plastic opening tool to separate and remove the bottom red casing. Do this by, pushing the tool into the seam and prying up the red casing as you move along the edges.
      • Make sure to separate all the corners before removing the red casing.
      Ask FixBot
    3. Samsung HMX-W200 Battery Replacement: step 3, image 1 of 2 Samsung HMX-W200 Battery Replacement: step 3, image 2 of 2
      • Using the plastic opening tool, separate and pull away the red casing on the right of the LCD screen.
      Ask FixBot
    4. Samsung HMX-W200 Battery Replacement: step 4, image 1 of 2 Samsung HMX-W200 Battery Replacement: step 4, image 2 of 2
      • To access the HDMI slot, move slider towards the bottom of the casing on the other side of the camcorder. The lid casing will lift up upon doing so.
      • After accessing the HDMI slot you will find a 5.00mm screw. Using a Phillips #00 screwdriver, remove the screw.
      Ask FixBot
    5. Samsung HMX-W200 Battery Replacement: step 5, image 1 of 2 Samsung HMX-W200 Battery Replacement: step 5, image 2 of 2
      • Using the plastic opening tool, separate and pull away the red casing to the left of the LCD screen.
      Ask FixBot
    6. Samsung HMX-W200 Battery Replacement: step 6, image 1 of 2 Samsung HMX-W200 Battery Replacement: step 6, image 2 of 2
      • Remove the six 5.00mm screws by using a Phillips #00 screwdriver.
      Ask FixBot
    7. Samsung HMX-W200 Battery Replacement: step 7, image 1 of 3 Samsung HMX-W200 Battery Replacement: step 7, image 2 of 3 Samsung HMX-W200 Battery Replacement: step 7, image 3 of 3
      • Lift the two plastic tabs on the left side of the LCD screen and the single one on the right side on the black casing to open the device.
      Ask FixBot
    8. Samsung HMX-W200 Battery Replacement: step 8, image 1 of 1
      • Separate the front and back casing.
      Ask FixBot
    1. Samsung HMX-W200 Battery Replacement, Battery: step 9, image 1 of 2 Samsung HMX-W200 Battery Replacement, Battery: step 9, image 2 of 2
      • Remove the four 4.00mm screws holding the battery brace using a Phillips #00 screwdriver.
      Ask FixBot
    2. Samsung HMX-W200 Battery Replacement: step 10, image 1 of 1
      • Using a plastic opening tool, lift the copper tab holding the battery brace in place.
      Ask FixBot
    3. Samsung HMX-W200 Battery Replacement: step 11, image 1 of 2 Samsung HMX-W200 Battery Replacement: step 11, image 2 of 2
      • Remove the battery brace and battery from the camera casing.
      • Remove the old battery from the brace and place the new one.
      • Your battery might be held to the brace by a copper tape. If so, you'll need to peel the tape away to remove it. This tape does not affect the battery's operation in any way, so it is safe to remove it.
      Ask FixBot
Ashton Esparza
101 Reputation
1 Guide authored
USF Tampa, Team 3-6, Sullivan Fall 2016 Member of USF Tampa, Team 3-6, Sullivan Fall 2016
USFT-SULLIVAN-F16S3G6
4 Members
84 Guides authored
0 Guide Comments
Past 24 Hours: 0
Past 7 Days: 5
Past 30 Days: 34
All Time: 1,471
