Samsung HMX-QF20 Lens Replacement
    1. Samsung HMX-QF20 Lens Replacement, Lens: step 1, image 1 of 1
      • Remove the 4 mm screw on the underside of the camcorder near the tripod mount.
      Ask FixBot
    2. Samsung HMX-QF20 Lens Replacement: step 2, image 1 of 1
      • Remove the 4 mm screw next to the buckle of the hand strap closest to the lens.
      Ask FixBot
    3. Samsung HMX-QF20 Lens Replacement: step 3, image 1 of 1
      • Open the LCD screen. Remove the 4 mm screw on the inside panel, located at top left corner.
      Ask FixBot
    4. Samsung HMX-QF20 Lens Replacement: step 4, image 1 of 1
      • Firmly grip and pull the front casing on the lens to remove it.
      • Be sure to remove the front casing at gently as possible to prevent damaging the attached ribbon cable. If not careful, the ribbon cables could be torn.
      Ask FixBot
    5. Samsung HMX-QF20 Lens Replacement: step 5, image 1 of 1
      • Remove the three 5 mm screws surrounding the lens.
      Ask FixBot
Renee
219 Reputation
2 Guides authored
Marist, Team 1-5, Laflen Spring 2015 Member of Marist, Team 1-5, Laflen Spring 2015
MARS-LAFLEN-S15S1G5
3 Members
48 Guides authored
0 Guide Comments
Past 24 Hours: 0
Past 7 Days: 10
Past 30 Days: 32
All Time: 997
