Up to 20% off select tools
Samsung HMX-F90 Record Button Replacement
Views: 1K
View statistics:
Past 24 Hours:
3
Past 7 Days:
15
Past 30 Days:
87
All Time:
1,003
Comments: 0
Go to guide comments
Completed: 0
Favorites: 0
Time Required: 15 - 20 minutes
Difficulty: Moderate
Tools
Introduction
Go to step 1 ↓
After several times of using buttons, they can become stuck or faulty. This guide can be used to loosen or replace the record button.
    1. Samsung HMX-F90 Record Button Replacement, Battery: step 1, image 1 of 3 Samsung HMX-F90 Record Button Replacement, Battery: step 1, image 2 of 3 Samsung HMX-F90 Record Button Replacement, Battery: step 1, image 3 of 3
      • Pull the release tab away from the battery.
      • Slide the battery towards the release tab and then pull the battery away from the camcorder.
      Ask FixBot
    1. Samsung HMX-F90 Record Button Replacement, Strap Side Outer Casing: step 2, image 1 of 2 Samsung HMX-F90 Record Button Replacement, Strap Side Outer Casing: step 2, image 2 of 2
      • Rotate the camcorder so that the strap side is facing you.
      • Locate and remove the three 4.5mm Phillips #00 screws around the hand strap.
      Ask FixBot
    2. Samsung HMX-F90 Record Button Replacement: step 3, image 1 of 2 Samsung HMX-F90 Record Button Replacement: step 3, image 2 of 2
      • Rotate the camcorder so that the battery slot is facing you.
      • Located in the top left corner of the battery slot, remove the 4.5mm Phillips #00 screw.
      Ask FixBot
    3. Samsung HMX-F90 Record Button Replacement: step 4, image 1 of 2 Samsung HMX-F90 Record Button Replacement: step 4, image 2 of 2
      • Rotate the camcorder so you are looking at the bottom of the camcorder.
      • Locate and remove the last three 4.5mm Phillips #00 screws.
      Ask FixBot
    4. Samsung HMX-F90 Record Button Replacement: step 5, image 1 of 3 Samsung HMX-F90 Record Button Replacement: step 5, image 2 of 3 Samsung HMX-F90 Record Button Replacement: step 5, image 3 of 3
      • With both hands, pull the side strap apart from the rest of the camcorder.
      Ask FixBot
    1. Samsung HMX-F90 Record Button Replacement, Record Button: step 6, image 1 of 3 Samsung HMX-F90 Record Button Replacement, Record Button: step 6, image 2 of 3 Samsung HMX-F90 Record Button Replacement, Record Button: step 6, image 3 of 3
      Tool used on this step:
      Buy
      • Locate plastic clips of the record button.
      • With tweezers squeeze together the two plastic clips and push the button out.
      • Wiggle and pull the record button to remove completely.
      Ask FixBot
Author
with
Amir Harb
705 Reputation
6 Guides authored
USF Tampa, Team S13-G1, Boczar Fall 2017 Member of USF Tampa, Team S13-G1, Boczar Fall 2017
USFT-BOCZAR-F17S13G1
4 Members
72 Guides authored
0 Guide Comments
Past 24 Hours: 3
Past 7 Days: 15
Past 30 Days: 87
All Time: 1,003
