Samsung HMX-F90 LCD Screen Replacement
Views: 2K
View statistics:
Past 24 Hours:
Past 7 Days:
16
Past 30 Days:
89
All Time:
1,991
Comments: 1
1 guide comment.
Go to guide comments
Completed: 0
Favorites: 0
Time Required: 30 - 45 minutes
Difficulty: Difficult
Introduction
Go to step 1 ↓
Cracked or faulty LCD screens can make the HMX-F90 difficult to use. This guide can be used to replace the flip-out LCD screen.
Tools
    1. Samsung HMX-F90 LCD Screen Replacement, LCD Screen: step 1, image 1 of 2 Samsung HMX-F90 LCD Screen Replacement, LCD Screen: step 1, image 2 of 2
      • Rotate the camcorder so that back is facing you. Then flip open the LCD screen.
      • Locate and remove the 4.5mm Phillips #00 screws in the LCD screen base.
      Ask FixBot
    2. Samsung HMX-F90 LCD Screen Replacement: step 2, image 1 of 2 Samsung HMX-F90 LCD Screen Replacement: step 2, image 2 of 2
      • Close the LCD screen. Then lift the silver base away from the camcorder.
      Ask FixBot
    3. Samsung HMX-F90 LCD Screen Replacement: step 3, image 1 of 2 Samsung HMX-F90 LCD Screen Replacement: step 3, image 2 of 2
      • Rotate the camcorder so that it is facing you.
      • Locate and remove the two 4.5mm Phillips #00 screws.
      Ask FixBot
    4. Samsung HMX-F90 LCD Screen Replacement: step 4, image 1 of 3 Samsung HMX-F90 LCD Screen Replacement: step 4, image 2 of 3 Samsung HMX-F90 LCD Screen Replacement: step 4, image 3 of 3
      • Open the LCD screen and rotate it around 90 degrees.
      • Locate the small prying notch and use a prying tool to slowly remove the LCD cover.
      Ask FixBot
    5. Samsung HMX-F90 LCD Screen Replacement: step 5, image 1 of 3 Samsung HMX-F90 LCD Screen Replacement: step 5, image 2 of 3 Samsung HMX-F90 LCD Screen Replacement: step 5, image 3 of 3
      • Locate and remove the two 3.5mm Phillips #00 screws holding the back cover.
      Ask FixBot
    6. Samsung HMX-F90 LCD Screen Replacement: step 6, image 1 of 3 Samsung HMX-F90 LCD Screen Replacement: step 6, image 2 of 3 Samsung HMX-F90 LCD Screen Replacement: step 6, image 3 of 3
      Tool used on this step:
      Buy
      • With tweezers gently unclip the silver tab holding the ribbon wire.
      • Gradually feed the ribbon wire through the hole to remove the screen.
      Ask FixBot
Amir Harb
705 Reputation
6 Guides authored
USF Tampa, Team S13-G1, Boczar Fall 2017 Member of USF Tampa, Team S13-G1, Boczar Fall 2017
USFT-BOCZAR-F17S13G1
4 Members
72 Guides authored
1 Guide Comment
How can I buy the LCD??
Mike - Reply Share
Past 24 Hours: 1
Past 7 Days: 16
Past 30 Days: 89
All Time: 1,991
