Up to 20% off select tools
Samsung HD Pro LED Light Ring Replacement
Views: 1.1K
View statistics:
Past 24 Hours:
3
Past 7 Days:
15
Past 30 Days:
95
All Time:
1,132
Comments: 0
Go to guide comments
Completed: 0
Favorites: 0
Time Required: 5 - 10 minutes
Difficulty: Easy
Better Introduction
Improve this guide by completing or revising its introduction.
Tools
    1. Samsung HD Pro LED Light Ring Replacement, Casing: step 1, image 1 of 1
      • Locate a small opening around the front panel of the camera.
      Ask FixBot
    2. Samsung HD Pro LED Light Ring Replacement: step 2, image 1 of 1
      • Using a plastic opening tool, apply pressure to various points around the camera to pry open the front panel.
      Ask FixBot
    3. Samsung HD Pro LED Light Ring Replacement: step 3, image 1 of 1
      • Remove both of the connecting wires from the motherboard.
      • Be careful to not bend headers or damage the wires.
      Ask FixBot
    4. Samsung HD Pro LED Light Ring Replacement: step 4, image 1 of 1
      • Apply a plastic opening tool to the gray plastic band around the case of the camera. Insert the edge of the spudger between the case of the camera and the gray plastic band.
      Ask FixBot
    5. Samsung HD Pro LED Light Ring Replacement: step 5, image 1 of 1
      • Apply pressure with the plastic opening tool to various areas of the gray plastic band to pry it from the white plastic back of the case.
      Ask FixBot
    1. Samsung HD Pro LED Light Ring Replacement, LED Light Ring: step 6, image 1 of 1
      • Locate the small circuit board surrounding the lens in the removed front portion of the device.
      Ask FixBot
    2. Samsung HD Pro LED Light Ring Replacement: step 7, image 1 of 1
      • Push the four white tabs away from the center of the lens housing while pulling the led ring up near each tab.
      Ask FixBot
Author
with
AllisonBridges
501 Reputation
5 Guides authored
0 Guide Comments
Past 24 Hours: 3
Past 7 Days: 15
Past 30 Days: 95
All Time: 1,132
