Repair Guides
Learn how to fix just about anything with our step-by-step guides.
App
Your pocket repair helper.
FixBot
The friendly AI repair assistant.
Repairability
Learn why fixable products make sense.
Teardowns
Get a sneak peek inside the latest gadgets.
Answers Forum
Share solutions and get help from a friend.
Find Your Community
Find teams, events, and fellow fixers.
Help Out
Help make repair knowledge free and accessible for everyone.
Right to Repair
Learn about the Right to Repair movement and how to be an advocate.
Featured
Quality parts and tools backed by our lifetime guarantee.
Tools
Shop our wide selection of precision tools.
Parts
Shop parts backed by our quality guarantee.
iPhone Batteries
Batteries tested and guaranteed plus a kit with everything you need.
Locate a small opening around the front panel of the camera.
Using a plastic opening tool, apply pressure to various points around the camera to pry open the front panel.
Remove both of the connecting wires from the motherboard.
Be careful to not bend headers or damage the wires.
Apply a plastic opening tool to the gray plastic band around the case of the camera. Insert the edge of the spudger between the case of the camera and the gray plastic band.
Apply pressure with the plastic opening tool to various areas of the gray plastic band to pry it from the white plastic back of the case.
On inside of front casing, locate heatsink.
Using careful force, push in the white tab and pry up heatsink with fingers.
Check to make sure all wires are completely detached from the motherboard.
Pull the circular circuit board away from the rest of the device, being careful not to bend any of the pins connecting the two.
Locate the three white tabs holding the next circuit board inside the case.
Press each tab while using a plastic spudger to pry the motherboard up in the location near the tab.
Unplug the final group of wires from the bottom of the second circuit board and remove the board.
On reverse side of second circuit board, locate secondary heatsink.
Using a Phillips #00 screwdriver, remove the screws holding the heatsink to the motherboard.
with 2 other contributors
501 Reputation
5 Guides authored
Badges: 7
+4 more badges
ARSU-CHAMBERLAIN-S17S1G1
4 Members
72 Guides authored
Choose a size and copy the code below to embed this guide as a small widget on your site / forum.
Past 24 Hours: 1
Past 7 Days: 4
Past 30 Days: 18
All Time: 624
