Up to 20% off select tools
Samsung Gravity TXT microSD Card Replacement
View statistics:
Past 24 Hours:
4
Past 7 Days:
15
Past 30 Days:
84
All Time:
756
Comments: 1
1 comment on steps.
Completed: 0
Favorites: 0
Time Required: 1 - 2 minutes
Difficulty: Very easy
Better Introduction
Improve this guide by completing or revising its introduction.
Tools
    1. Samsung Gravity TXT microSD Card  Replacement, Battery: step 1, image 1 of 2 Samsung Gravity TXT microSD Card  Replacement, Battery: step 1, image 2 of 2
      • Pry the back cover off with a plastic opening tool, or your fingernail, in the indentation on the bottom of the device.
      Ask FixBot
    2. Samsung Gravity TXT microSD Card  Replacement: step 2, image 1 of 1
      • Lift the back cover away from the main body of the phone.
      Ask FixBot
    3. Samsung Gravity TXT microSD Card  Replacement: step 3, image 1 of 1
      • Insert your finger in the groove below the battery.
      • Press the battery toward the audio jack while lifting upward and away from the phone.
      • Remember to place the battery back with the copper contacts on the battery lined up with those on the phone.
      Ask FixBot
    1. Samsung Gravity TXT microSD Card  Replacement, microSD Card: step 4, image 1 of 3 Samsung Gravity TXT microSD Card  Replacement, microSD Card: step 4, image 2 of 3 Samsung Gravity TXT microSD Card  Replacement, microSD Card: step 4, image 3 of 3
      • Using your fingernail, push the microSD card slightly deeper into the slot, until you hear a click.
      • The removal of the battery is not required for this operation; therefore, step 3 can be skipped if just replacing the microSD card.
      • After the click, release the microSD card to allow it to pop out.
      • Remove the microSD card from its slot
      • When placing the microSD card back in the phone, make sure the card clicks in place.
      Ask FixBot
Author
with
Mounir Karmada
465 Reputation
4 Guides authored
IUPUI, Team 1-1, Renguette SU 2015 Member of IUPUI, Team 1-1, Renguette SU 2015
IUPUI-RENGUETTE-SU15S1G1
5 Members
96 Guides authored
0 Guide Comments
Past 24 Hours: 4
Past 7 Days: 15
Past 30 Days: 84
All Time: 756
