Up to 20% off select tools
Samsung Gravity TXT SIM Card Replacement
Views: 1.5K
View statistics:
Past 24 Hours:
3
Past 7 Days:
16
Past 30 Days:
84
All Time:
1,533
Comments: 1
1 comment on steps.
Completed: 0
Favorites: 0
Time Required: 1 - 2 minutes
Difficulty: Very easy
Better Introduction
Improve this guide by completing or revising its introduction.
Tools
    1. Samsung Gravity TXT SIM Card Replacement, Battery: step 1, image 1 of 2 Samsung Gravity TXT SIM Card Replacement, Battery: step 1, image 2 of 2
      • Pry the back cover off with a plastic opening tool, or your fingernail, in the indentation on the bottom of the device.
      Ask FixBot
    2. Samsung Gravity TXT SIM Card Replacement: step 2, image 1 of 1
      • Lift the back cover away from the main body of the phone.
      Ask FixBot
    3. Samsung Gravity TXT SIM Card Replacement: step 3, image 1 of 1
      • Insert your finger in the groove below the battery.
      • Press the battery toward the audio jack while lifting upward and away from the phone.
      • Remember to place the battery back with the copper contacts on the battery lined up with those on the phone.
      Ask FixBot
    1. Samsung Gravity TXT SIM Card Replacement, SIM Card: step 4, image 1 of 3 Samsung Gravity TXT SIM Card Replacement, SIM Card: step 4, image 2 of 3 Samsung Gravity TXT SIM Card Replacement, SIM Card: step 4, image 3 of 3
      • Using your finger, push the SIM Card down and slide out of the slot.
      • Slide the SIM card out enough to grab it firmly.
      • Remove the SIM card away from the phone.
      • Follow the visual on the bottom of the SIM card slot to put the SIM card back in the correct orientation.
      • When sliding the SIM Card back in the slot, make sure the card goes all the way in the slot until it hits the stopper.
      Ask FixBot
Author
with
Mounir Karmada
465 Reputation
4 Guides authored
IUPUI, Team 1-1, Renguette SU 2015 Member of IUPUI, Team 1-1, Renguette SU 2015
IUPUI-RENGUETTE-SU15S1G1
5 Members
96 Guides authored
0 Guide Comments
Past 24 Hours: 3
Past 7 Days: 16
Past 30 Days: 84
All Time: 1,533
