Up to 20% off select tools
Samsung Glyde Keyboard Replacement
Views: 1.9K
View statistics:
Past 24 Hours:
4
Past 7 Days:
17
Past 30 Days:
93
All Time:
1,873
Comments: 0
Go to guide comments
Completed: 0
Favorites: 4
4 people have favorited (and subscribed to) this guide. Will you be next?
Time Required: 25 minutes
Difficulty: Moderate
Action Shots
Be an action hero! This guide needs images that better demonstrate how to perform specific actions.
Tools
Introduction
Go to step 1 ↓
This guide will provide a step by step procedure for installing the keyboard.
    1. Samsung Glyde Keyboard Replacement, Battery: step 1, image 1 of 1
      • Caution: Hazardous situation which, if not avoided, could result in minor or moderate injury. Make sure the device is completely turned off before the repair. The battery should not be removed while the phone is on.
      • Using your thumb, press down and slide the back cover away from the camera.
      Ask FixBot
    2. Samsung Glyde Keyboard Replacement: step 2, image 1 of 1
      • Remove the battery from the phone by using your plastic opening tool to find a gap at any edge of the battery and lifting the battery up.
      Ask FixBot
    1. Samsung Glyde Keyboard Replacement, Keyboard: step 3, image 1 of 2 Samsung Glyde Keyboard Replacement, Keyboard: step 3, image 2 of 2
      • Use a Phillips #00 screwdriver to remove the six 4mm screws.
      Ask FixBot
    2. Samsung Glyde Keyboard Replacement: step 4, image 1 of 2 Samsung Glyde Keyboard Replacement: step 4, image 2 of 2
      • Find a gap on the top side of the phone and pry apart the phone case using the plastic opening tool . Use moderate pressure to slowly maneuver around until the case is pryed apart.
      • Take the case off with your fingers
      Ask FixBot
    3. Samsung Glyde Keyboard Replacement: step 5, image 1 of 2 Samsung Glyde Keyboard Replacement: step 5, image 2 of 2
      • The green film is located above the camera. It is the camera connector to the motherboard.
      • Disconnect the camera connector with the plastic opening tool.
      Ask FixBot
    4. Samsung Glyde Keyboard Replacement: step 6, image 1 of 2 Samsung Glyde Keyboard Replacement: step 6, image 2 of 2
      • Take a close up of the picture for this step for a better view.
      • Use a plastic opening tool to disconnect the keyboard connector.
      Ask FixBot
    5. Samsung Glyde Keyboard Replacement: step 7, image 1 of 2 Samsung Glyde Keyboard Replacement: step 7, image 2 of 2
      • The motherboard is held in place by the circular connector.
      • Using a plastic opening tool, disconnect the circular connector.
      Ask FixBot
    6. Samsung Glyde Keyboard Replacement: step 8, image 1 of 3 Samsung Glyde Keyboard Replacement: step 8, image 2 of 3 Samsung Glyde Keyboard Replacement: step 8, image 3 of 3
      • A LCD connector is located underneath the motherboard.
      • Lift the far edge of the motherboard gently upwards toward the center.
      • Using a plastic opening tool, disconnect the LCD connector.
      Ask FixBot
    7. Samsung Glyde Keyboard Replacement: step 9, image 1 of 2 Samsung Glyde Keyboard Replacement: step 9, image 2 of 2
      • Lift the motherboard up with your fingers.
      • Place the motherboard in a secure area.
      Ask FixBot
    8. Samsung Glyde Keyboard Replacement: step 10, image 1 of 3 Samsung Glyde Keyboard Replacement: step 10, image 2 of 3 Samsung Glyde Keyboard Replacement: step 10, image 3 of 3
      • Look for the antenna which is located at the bottom end of the device. Prop the antenna out by using the plastic opening tool and slipping the tip of the tool into the edges of the antenna.
      • Using the plastic opening tool, disconnect the connector that leads from the phone to the antenna.
      • With your hands finish prying apart the antenna by lifting it up.
      Ask FixBot
    9. Samsung Glyde Keyboard Replacement: step 11, image 1 of 2 Samsung Glyde Keyboard Replacement: step 11, image 2 of 2
      • The keyboard chip is located on top of the device. Pry the keyboard off of the case with the plastic opening tool.
      Ask FixBot
Author
with
Cameron Law
142 Reputation
5 Guides authored
Cal Poly, Team 3-12, Regan Fall 2011 Member of Cal Poly, Team 3-12, Regan Fall 2011
CPSU-REGAN-F11S3G12
4 Members
84 Guides authored
0 Guide Comments
Past 24 Hours: 4
Past 7 Days: 17
Past 30 Days: 93
All Time: 1,873
