Up to 20% off select tools
Samsung Glyde Battery Replacement
Views: 2K
View statistics:
Past 24 Hours:
4
Past 7 Days:
17
Past 30 Days:
113
All Time:
1,975
Comments: 0
Go to guide comments
Completed: 0
Favorites: 1
1 person has favorited (and subscribed to) this guide. Will you be next?
Time Required: 1 minute
Difficulty: Very easy
Introduction
Go to step 1 ↓
This guide provides a step-by-step procedure for replacing the Samsung Glyde Battery. If your device is not charging or not holding a charge, a replacement would be beneficial. After replacing the Samsung phone battery, it should continue working normally. You don't need any special skills or tools to do this task. Be cautious and aware that the battery is a lithium-ion battery. However, since it is a user, removable battery, this process should be straightforward.
    1. Samsung Glyde Battery Replacement, Battery: step 1, image 1 of 1
      • Caution: Hazardous situation which, if not avoided, could result in minor or moderate injury. Make sure the device is completely turned off before the repair. The battery should not be removed while the phone is on.
      • Using your thumb, press down and slide the back cover away from the camera.
      Ask FixBot
    2. Samsung Glyde Battery Replacement: step 2, image 1 of 1
      • Remove the battery from the phone by using your plastic opening tool to find a gap at any edge of the battery and lifting the battery up.
      Ask FixBot
Author
with
Cameron Law
142 Reputation
5 Guides authored
Cal Poly, Team 3-12, Regan Fall 2011 Member of Cal Poly, Team 3-12, Regan Fall 2011
CPSU-REGAN-F11S3G12
4 Members
84 Guides authored
0 Guide Comments
Past 24 Hours: 4
Past 7 Days: 17
Past 30 Days: 113
All Time: 1,975
