Samsung Glyde Antenna Replacement
    1. Samsung Glyde Antenna Replacement, Battery: step 1, image 1 of 1
      • Using your thumb, press down and slide the back cover away from the camera.
      Ask FixBot
    2. Samsung Glyde Antenna Replacement: step 2, image 1 of 1
      • Remove the battery from the phone by using your plastic opening tool to find a gap at any edge of the battery and lifting the battery up.
      Ask FixBot
    1. Samsung Glyde Antenna Replacement, Antenna: step 3, image 1 of 2 Samsung Glyde Antenna Replacement, Antenna: step 3, image 2 of 2
      • Using a Phillips #00 screwdriver, remove the six 4mm screws holding the back case together.
      Ask FixBot
    2. Samsung Glyde Antenna Replacement: step 4, image 1 of 2 Samsung Glyde Antenna Replacement: step 4, image 2 of 2
      • Use a plastic opening tool to pry the case off. To do this, find a gap on any side of the phone, top preferably, and slip the tip of the tool in the gap.
      • Now use moderate strength and slowly maneuver the tool around the outside until the case becomes loose.
      • Using your fingers, take the case off.
      Ask FixBot
    3. Samsung Glyde Antenna Replacement: step 5, image 1 of 2 Samsung Glyde Antenna Replacement: step 5, image 2 of 2
      • The antenna is located on the bottom of the phone. It is the small rectangular shaped object sticking out on one of the ends.
      • Use a plastic opening tool to prop the antenna out. To do so, slip the tip of the tool on one of the edges of the antenna. Use moderate pressure to pry the antenna out.
      Ask FixBot
    4. Samsung Glyde Antenna Replacement: step 6, image 1 of 2 Samsung Glyde Antenna Replacement: step 6, image 2 of 2
      • Using a plastic opening tool, disconnect the connector leading from the antenna to the phone.
      Ask FixBot
Cameron Law
142 Reputation
5 Guides authored
Cal Poly, Team 3-12, Regan Fall 2011 Member of Cal Poly, Team 3-12, Regan Fall 2011
CPSU-REGAN-F11S3G12
4 Members
84 Guides authored
0 Guide Comments
Past 24 Hours: 2
Past 7 Days: 6
Past 30 Days: 37
All Time: 1,718
