Samsung Gear VR USB Connector Replacement
    1. Samsung Gear VR USB Connector Replacement, USB Connector Replacement: step 1, image 1 of 1
      • Remove front cover from headset.
      Ask FixBot
    2. Samsung Gear VR USB Connector Replacement: step 2, image 1 of 1
      • Slide the latch to the right to unlock the current connector.
      Ask FixBot
    3. Samsung Gear VR USB Connector Replacement: step 3, image 1 of 2 Samsung Gear VR USB Connector Replacement: step 3, image 2 of 2
      • Lift connector clip away from headset and towards you.
      • Slide current connector out and away from headset until it is disconnected from connector clip.
      Ask FixBot
    4. Samsung Gear VR USB Connector Replacement: step 4, image 1 of 1
      • Select which connector fits the port of the device you wish to use with the Samsung Gear VR.
      • The Samsung Gear VR is packaged with connectors for Micro USB and USB-C.
      Ask FixBot
    5. Samsung Gear VR USB Connector Replacement: step 5, image 1 of 2 Samsung Gear VR USB Connector Replacement: step 5, image 2 of 2
      • Slide the connector that connects to your device back onto the connector clip until you feel it settle into place.
      • Slide the lock latch to the left to secure the connector into place.
      Ask FixBot
3 other people completed this guide.
Alfredo Aparicio
325 Reputation
3 Guides authored
USF Tampa, Team S4-G6, Eyestone Fall 2017 Member of USF Tampa, Team S4-G6, Eyestone Fall 2017
USFT-EYESTONE-F17S4G6
4 Members
84 Guides authored
5 Guide Comments
Hola, quisiera saber donde se consigue esa parte, ni siquiera en samsung lo he logrado
Jose Davinci - Reply Share
Were do I get the USB c adapter
helenpaul77 - Reply Share
If you want USB c adapter I can give you…but we have to make exchange because I need micro usb adapter not type c
Molefi Aaron - Reply Share
I have the micro USB adapter and need type c. Please advise as to how this barter may be executed?
Saleem A. Sheikh - Reply Share
Where can I get micro USB converter for gear vr not type c
Past 24 Hours: 5
Past 7 Days: 19
Past 30 Days: 99
All Time: 18,343
