Up to 20% off select tools
Samsung Gear VR Lens Replacement
Views: 7.2K
View statistics:
Past 24 Hours:
5
Past 7 Days:
21
Past 30 Days:
120
All Time:
7,242
Comments: 1
1 guide comment.
Go to guide comments
Completed: 1
1 person has marked this guide "completed." Will you be next?
Favorites: 1
1 person has favorited (and subscribed to) this guide. Will you be next?
Time Required: 25 - 30 minutes
Difficulty: Moderate
Parts
Tools
Introduction
Go to step 1 ↓
It is possible for the headset's lenses to become scratched, chipped, or simply dirty. The following guide will outline how to access the lenses for replacement or cleaning.
The motherboard partially sits on the inner mask piece of the headset and must be removed in order to remove the inner mask piece.
Caution is required while working on the headset as a wire harness connects the USB adapter to the motherboard. Care should be taken not to put any strain on the wire and to open the headset from right to left.
    1. Samsung Gear VR Lens Replacement, Front Phone Mount: step 1, image 1 of 3 Samsung Gear VR Lens Replacement, Front Phone Mount: step 1, image 2 of 3 Samsung Gear VR Lens Replacement, Front Phone Mount: step 1, image 3 of 3
      • Remove the front cover to access a plate that holds the phone in place during use.
      • Remove the four corner screw covers with a metal spudger to reveal four screws.
      • Remove the sticker located at the top center to reveal two additional screws.
      Ask FixBot
    2. Samsung Gear VR Lens Replacement: step 2, image 1 of 2 Samsung Gear VR Lens Replacement: step 2, image 2 of 2
      • Using the PH000 tip remove the six 0.5 cm screws that secure the front phone mount.
      • After the six 0.5 cm screws are completely removed lift the front phone mount up and to the left.
      • When handling your equipment be careful not to strain the wire harness located on the left side of the headset.
      Ask FixBot
    1. Samsung Gear VR Lens Replacement, Motherboard: step 3, image 1 of 1
      • Use the blue plastic opening tool to remove the rest of the the pop connectors from the motherboard.
      • The larger gold connector is lightly glued down so it may take more effort to remove than the others.
      Ask FixBot
    2. Samsung Gear VR Lens Replacement: step 4, image 1 of 1
      • You can now remove the motherboard from the mask.
      • Make sure that nothing is connected to the motherboard before you try to remove it as pulling it with something connect might brake the connections.
      Ask FixBot
    1. Samsung Gear VR Lens Replacement, Inner Mask: step 5, image 1 of 3 Samsung Gear VR Lens Replacement, Inner Mask: step 5, image 2 of 3 Samsung Gear VR Lens Replacement, Inner Mask: step 5, image 3 of 3
      • Using the PH000 tip remove the eight 0.5 cm screws from the Inner Mask
      • Carefully remove the Inner Mask by pulling it from the inner side of the lenses socket.
      Ask FixBot
    1. Samsung Gear VR Lens Replacement, Lens: step 6, image 1 of 2 Samsung Gear VR Lens Replacement, Lens: step 6, image 2 of 2
      • Using the metal spudger, push in the 3 tabs around the lens housing to release the lens. Repeat for both lens for a total of 6 tabs.
      • Do not push in too hard or you might brake the tabs.
      Ask FixBot
    2. Samsung Gear VR Lens Replacement: step 7, image 1 of 1
      • Flip the headgear and use your fingers to gently remove lens from mask. Repeat for both lens.
      Ask FixBot
Author
with
Abraham Rodriguez
245 Reputation
2 Guides authored
USF Tampa, Team S4-G6, Eyestone Fall 2017 Member of USF Tampa, Team S4-G6, Eyestone Fall 2017
USFT-EYESTONE-F17S4G6
4 Members
84 Guides authored
1 Guide Comment
There are multiple mistakes in this tutorial, which made it hard to follow the steps:
- in step 2.1, you are missing 4 screws below each side of the latching mechanism.
- in step 5, the mask does not come apart after unscrewing the 8 screws. I am currently stuck at this step as I am writing this. Wish me luck.
L.H. - Reply Share
Past 24 Hours: 5
Past 7 Days: 21
Past 30 Days: 120
All Time: 7,242
