Samsung Gear S3 Frontier Motherboard Replacement
    1. Samsung Gear S3 Frontier Motherboard Replacement, Back Cover: step 1, image 1 of 1
      • Place the watch screen-down so that its back cover is showing.
      Ask FixBot
    2. Samsung Gear S3 Frontier Motherboard Replacement: step 2, image 1 of 2 Samsung Gear S3 Frontier Motherboard Replacement: step 2, image 2 of 2
      • Remove the four 4.2mm screws with a Y00 screwdriver.
      Ask FixBot
    3. Samsung Gear S3 Frontier Motherboard Replacement: step 3, image 1 of 3 Samsung Gear S3 Frontier Motherboard Replacement: step 3, image 2 of 3 Samsung Gear S3 Frontier Motherboard Replacement: step 3, image 3 of 3
      • This step will ruin the water-proof seal.
      • Wedge the metal spudger in between the back cover and the frame along the seam.
      • Use force to pry the back cover away from the main watch frame.
      • This step requires a lot of force. You can use a Jimmy in place of a metal spudger to make the process easier.
      Ask FixBot
    1. Samsung Gear S3 Frontier Motherboard Replacement, Front Screen Assembly: step 4, image 1 of 3 Samsung Gear S3 Frontier Motherboard Replacement, Front Screen Assembly: step 4, image 2 of 3 Samsung Gear S3 Frontier Motherboard Replacement, Front Screen Assembly: step 4, image 3 of 3
      • Detach the three connectors on the motherboard using your fingernail.
      • The connectors are easy to pop off. Minimal force is necessary.
      Ask FixBot
    2. Samsung Gear S3 Frontier Motherboard Replacement: step 5, image 1 of 3 Samsung Gear S3 Frontier Motherboard Replacement: step 5, image 2 of 3 Samsung Gear S3 Frontier Motherboard Replacement: step 5, image 3 of 3
      • Separate the motherboard and front screen assembly using a spudger.
      Ask FixBot
    1. Samsung Gear S3 Frontier Motherboard Replacement, Battery: step 6, image 1 of 2 Samsung Gear S3 Frontier Motherboard Replacement, Battery: step 6, image 2 of 2
      • Using a JIS #00 screwdriver, remove the two 4.5 mm screws.
      Ask FixBot
    2. Samsung Gear S3 Frontier Motherboard Replacement: step 7, image 1 of 3 Samsung Gear S3 Frontier Motherboard Replacement: step 7, image 2 of 3 Samsung Gear S3 Frontier Motherboard Replacement: step 7, image 3 of 3
      • Disconnect the battery ribbon cable from bracket.
      • Be careful with the battery ribbon cable and motherboard cable (located on the side opposite the battery cable, highlighted with the orange box), as they are very easy to break (ours did when disassembling).
      • Note how the end of the ribbon cable seats in the plastic chassis. Look for the plastic pin on the chassis when re-seating during re-assembly.
      • Separate the chassis from the motherboard.
      Ask FixBot
    3. Samsung Gear S3 Frontier Motherboard Replacement: step 8, image 1 of 2 Samsung Gear S3 Frontier Motherboard Replacement: step 8, image 2 of 2
      • Separate the battery from the motherboard.
      • The battery and the motherboard are secured with adhesive; some force is needed.
      • Lithium-ion batteries are potentially dangerous. Handle with extreme care and do not puncture the battery.
      Ask FixBot
    4. Samsung Gear S3 Frontier Motherboard Replacement: step 9, image 1 of 2 Samsung Gear S3 Frontier Motherboard Replacement: step 9, image 2 of 2
      • When reassembling, place the battery into the plastic assembly first. Don’t stick it to the adhesive first. This way, it’s easy to position the battery cable.
      • When securing the battery cable, make sure the hole that the peg goes through is round. The hole on your replacement battery’s cable could be malformed. You may want to widen the hole before securing the cable.
      • To widen the hole, use the Pro Tech Toolkit’s SIM tool, a small paperclip or similar fine-tipped tool. The tool can also be used to gently press the battery cable into the correct position. Do this carefully to avoid damage.
      • Follow steps 8-1 in reverse order to reassmble.
      Ask FixBot
    1. Samsung Gear S3 Frontier Motherboard Replacement, Motherboard: step 10, image 1 of 3 Samsung Gear S3 Frontier Motherboard Replacement, Motherboard: step 10, image 2 of 3 Samsung Gear S3 Frontier Motherboard Replacement, Motherboard: step 10, image 3 of 3
      Tool used on this step:
      Buy
      • Remove the battery's cable from the chassis using tweezers.
      Ask FixBot
5 other people completed this guide.
William Hurty
2,819 Reputation
3 Guides authored
Cal Poly, Team S15-G2, White Fall 2018 Member of Cal Poly, Team S15-G2, White Fall 2018
CPSU-WHITE-F18S15G2
4 Members
84 Guides authored
11 Guide Comments
Where can I purchase a motherboard for my Samsung Gears s3. Cant seem to find them
Mel Swint - Reply Share
Need motherboard for samsung gears
Try ebay Mel
Dave Miller - Reply Share
Hello I was in MRI and my watch was unresponsive. What is the problem?
Shaymaa - Reply Share
My button Ribbon on my Mainboard has come detached. It seams like there was some adhesive holding it on so i pressed it together. put it back together but the buttons wont turn the watch on. it is charged. I can’t tell if the Ribbon was soldered on or some adhesive used to make those connections. Any help would be appreciated.
Rollins Gamer - Reply Share
Past 24 Hours: 3
Past 7 Days: 23
Past 30 Days: 114
All Time: 22,301
