Samsung Gear S3 Frontier Front Screen Assembly Replacement
Views: 23K
View statistics:
Past 24 Hours:
4
Past 7 Days:
31
Past 30 Days:
118
All Time:
23,264
Comments: 35
26 comments on steps, 9 guide comments.
Go to guide comments
Completed: 14
14 people have marked this guide "completed." Will you be next?
Favorites: 0
Time Required: 10 - 45 minutes
Difficulty: Moderate
Introduction
Go to step 1 ↓
If your device's touchscreen is unresponsive or cracked, replace it with this guide. This will require you to replace the whole front screen assembly, as you can't just replace the screen itself.
Tools
    1. Samsung Gear S3 Frontier Front Screen Assembly Replacement, Back Cover: step 1, image 1 of 1
      • Place the watch screen-down so that its back cover is showing.
      Ask FixBot
    2. Samsung Gear S3 Frontier Front Screen Assembly Replacement: step 2, image 1 of 2 Samsung Gear S3 Frontier Front Screen Assembly Replacement: step 2, image 2 of 2
      • Remove the four 4.2mm screws with a Y00 screwdriver.
      Ask FixBot
    3. Samsung Gear S3 Frontier Front Screen Assembly Replacement: step 3, image 1 of 3 Samsung Gear S3 Frontier Front Screen Assembly Replacement: step 3, image 2 of 3 Samsung Gear S3 Frontier Front Screen Assembly Replacement: step 3, image 3 of 3
      • This step will ruin the water-proof seal.
      • Wedge the metal spudger in between the back cover and the frame along the seam.
      • Use force to pry the back cover away from the main watch frame.
      • This step requires a lot of force. You can use a Jimmy in place of a metal spudger to make the process easier.
      Ask FixBot
    1. Samsung Gear S3 Frontier Front Screen Assembly Replacement, Front Screen Assembly: step 4, image 1 of 3 Samsung Gear S3 Frontier Front Screen Assembly Replacement, Front Screen Assembly: step 4, image 2 of 3 Samsung Gear S3 Frontier Front Screen Assembly Replacement, Front Screen Assembly: step 4, image 3 of 3
      • Detach the three connectors on the motherboard using your fingernail.
      • The connectors are easy to pop off. Minimal force is necessary.
      Ask FixBot
    2. Samsung Gear S3 Frontier Front Screen Assembly Replacement: step 5, image 1 of 3 Samsung Gear S3 Frontier Front Screen Assembly Replacement: step 5, image 2 of 3 Samsung Gear S3 Frontier Front Screen Assembly Replacement: step 5, image 3 of 3
      • Separate the motherboard and front screen assembly using a spudger.
      Ask FixBot
14 other people completed this guide.
Jimmy Algeo
883 Reputation
2 Guides authored
Cal Poly, Team S15-G2, White Fall 2018 Member of Cal Poly, Team S15-G2, White Fall 2018
CPSU-WHITE-F18S15G2
4 Members
84 Guides authored
9 Guide Comments
can you tell me where can i buy the whole front screen  ?
Ahmad Hariki - Reply Share
Jerzy Jerzyk - Reply Share
Same question, I am having great difficulty in locating the PARTS to complete these repairs. Can someone please list where we can actually purchase the replacement parts that are shown in these guides??
ArcadeDude44 - Reply Share
Can anyone please tell, where to get the parts?
Sunny Tate - Reply Share
Eleazar Lagundino - Reply Share
Past 24 Hours: 4
Past 7 Days: 31
Past 30 Days: 118
All Time: 23,264
