Samsung Gear S2 Motherboard Replacement
  1. Samsung Gear S2 Motherboard Replacement, Watch Strap: step 1, image 1 of 2 Samsung Gear S2 Motherboard Replacement, Watch Strap: step 1, image 2 of 2
    • Flip the watch over so that the face is down.
    • Using a Y#0 screwdriver, unscrew the four 3.5 millimeter tri-head screws.
    • Remember to turn off the watch to avoid being shocked.
    Ask FixBot
  2. Samsung Gear S2 Motherboard Replacement: step 2, image 1 of 2 Samsung Gear S2 Motherboard Replacement: step 2, image 2 of 2
    • Using your finger, push forward on the release while pulling up on the strap.
    • You may find it helpful to use the flat end of a spudger to push on the release instead of your finger.
    Ask FixBot
  3. Samsung Gear S2 Motherboard Replacement: step 3, image 1 of 2 Samsung Gear S2 Motherboard Replacement: step 3, image 2 of 2
    • Repeat the procedure from step 2 for the other strap.
    Ask FixBot
  4. Samsung Gear S2 Motherboard Replacement, Back: step 4, image 1 of 2 Samsung Gear S2 Motherboard Replacement, Back: step 4, image 2 of 2
    • Insert a plastic opening tool between the top and bottom portions of the case, and gently pry off the back.
    • Do not insert the tool more than 3 millimeters into the case. Inserting more than 3 mm may damage the seal and electric components.
    Ask FixBot
  5. Samsung Gear S2 Motherboard Replacement, Motherboard: step 5, image 1 of 2 Samsung Gear S2 Motherboard Replacement, Motherboard: step 5, image 2 of 2
    • Using a Philips head #00 screwdriver, remove the two 3.6 millimeter screws.
    Ask FixBot
  6. Samsung Gear S2 Motherboard Replacement: step 6, image 1 of 3 Samsung Gear S2 Motherboard Replacement: step 6, image 2 of 3 Samsung Gear S2 Motherboard Replacement: step 6, image 3 of 3
    • Using a spudger, pry up the three cables.
    Ask FixBot
  7. Samsung Gear S2 Motherboard Replacement: step 7, image 1 of 2 Samsung Gear S2 Motherboard Replacement: step 7, image 2 of 2
    • Using the flat end of a spudger, pry up the motherboard.
    • Make sure the cable is fed through the hole to avoid damaging it.
    • The motherboard is attached to the battery casing, so place the motherboard in the orientation shown once freed.
    Ask FixBot
7 other people completed this guide.
Jacob Baldwin
3,459 Reputation
5 Guides authored
USF Tampa, Team S2-G3, Sullivan Spring 2017 Member of USF Tampa, Team S2-G3, Sullivan Spring 2017
USFT-SULLIVAN-S17S2G3
3 Members
23 Guides authored
6 Guide Comments
Where do you get the mother board.
Walter Meekins - Reply Share
I'm looking for a new motherboard as well.
Karen - Reply Share
Where do you buy a motherboard???
kiki3w - Reply Share
Do you have a good source for motherboards? Hope it helps that I +30’d you!
darkfeather72 - Reply Share
Ok motherboard replaced but how can I have the watch to work in normal mode and not in factory release.?
Cyan - Reply Share
Past 24 Hours: 3
Past 7 Days: 13
Past 30 Days: 47
All Time: 17,697
