Samsung Gear S Speaker Replacement
  1. Samsung Gear S Speaker Replacement, Display Assembly: step 1, image 1 of 3 Samsung Gear S Speaker Replacement, Display Assembly: step 1, image 2 of 3 Samsung Gear S Speaker Replacement, Display Assembly: step 1, image 3 of 3
    • Remove the wrist strap by peeling back the rubber starting from one corner of the watch face. Continue peeling the rubber away from the watch face until the strap is completely off.
    Ask FixBot
  2. Samsung Gear S Speaker Replacement: step 2, image 1 of 2 Samsung Gear S Speaker Replacement: step 2, image 2 of 2
    • Starting from an edge, wedge a metal spudger in between the screen and the chrome trim ring and pry, lifting the screen outwards.
    • Some force is needed due to adhesive seal.
    Ask FixBot
  3. Samsung Gear S Speaker Replacement: step 3, image 1 of 1
    • Use a plastic opening tool to gently pry upwards on the plastic motherboard assembly.
    Ask FixBot
  4. Samsung Gear S Speaker Replacement: step 4, image 1 of 1
    • Locate the ribbon assembly attaching the display to the motherboard.
    Ask FixBot
  5. Samsung Gear S Speaker Replacement: step 5, image 1 of 1
    • Use a plastic opening tool to detach the glass screen/ LED Display ribbon connector from the motherboard.
    Ask FixBot
  6. Samsung Gear S Speaker Replacement: step 6, image 1 of 1
    • Now the watch should be in three separate pieces.
    Ask FixBot
  7. Samsung Gear S Speaker Replacement, Speaker: step 7, image 1 of 1
    • Locate the speaker in the upper left corner of the housing.
    • Locate the speaker ribbon connector directly below the speaker.
    Ask FixBot
  8. Samsung Gear S Speaker Replacement: step 8, image 1 of 1
    • Use the plastic opening tool to gently pry upwards on the speaker's ribbon connector.
    Ask FixBot
  9. Samsung Gear S Speaker Replacement: step 9, image 1 of 1
    • Use the spudger to gently pry upwards on the speaker housing.
    • Note: The speaker housing is attached with adhesive, therefore, some force is required.
    Ask FixBot
3 other people completed this guide.
Luis Franco
1,076 Reputation
4 Guides authored
USF Tampa, Team 12-1, Blackwell Fall 2015 Member of USF Tampa, Team 12-1, Blackwell Fall 2015
USFT-BLACKWELL-F15S12G1
4 Members
5 Guides authored
2 Guide Comments
Do you have a place where we can buy the speaker part?
christopher borget - Reply Share
Ya. Looking for speaker part myself... Where we find it at?
Tony Tone - Reply Share
Past 24 Hours: 0
Past 7 Days: 7
Past 30 Days: 34
All Time: 3,683
