Samsung Gear S Microphone Replacement
Views: 2.9K
View statistics:
Past 24 Hours:
3
Past 7 Days:
15
Past 30 Days:
83
All Time:
2,919
Comments: 15
12 comments on steps, 3 guide comments.
Go to guide comments
Completed: 3
3 people have marked this guide "completed." Will you be next?
Favorites: 3
3 people have favorited (and subscribed to) this guide. Will you be next?
Time Required: 25 minutes
Difficulty: Moderate
Needs Better Images
Better photos will improve this guide. Help out by taking, editing, or uploading new ones!
Introduction
Go to step 1 ↓
This guide will give step by step instructions showing how to repair the microphone on the Samsung Gear S.
Tools
    1. Samsung Gear S Microphone Replacement, Display Assembly: step 1, image 1 of 3 Samsung Gear S Microphone Replacement, Display Assembly: step 1, image 2 of 3 Samsung Gear S Microphone Replacement, Display Assembly: step 1, image 3 of 3
      • Remove the wrist strap by peeling back the rubber starting from one corner of the watch face. Continue peeling the rubber away from the watch face until the strap is completely off.
      Ask FixBot
    2. Samsung Gear S Microphone Replacement: step 2, image 1 of 2 Samsung Gear S Microphone Replacement: step 2, image 2 of 2
      • Starting from an edge, wedge a metal spudger in between the screen and the chrome trim ring and pry, lifting the screen outwards.
      • Some force is needed due to adhesive seal.
      Ask FixBot
    3. Samsung Gear S Microphone Replacement: step 3, image 1 of 1
      • Use a plastic opening tool to gently pry upwards on the plastic motherboard assembly.
      Ask FixBot
    4. Samsung Gear S Microphone Replacement: step 4, image 1 of 1
      • Locate the ribbon assembly attaching the display to the motherboard.
      Ask FixBot
    5. Samsung Gear S Microphone Replacement: step 5, image 1 of 1
      • Use a plastic opening tool to detach the glass screen/ LED Display ribbon connector from the motherboard.
      Ask FixBot
    6. Samsung Gear S Microphone Replacement: step 6, image 1 of 1
      • Now the watch should be in three separate pieces.
      Ask FixBot
    1. Samsung Gear S Microphone Replacement, Microphone: step 7, image 1 of 1
      • Locate the microphone on the lower right corner of the plastic motherboard assembly .
      Ask FixBot
    2. Samsung Gear S Microphone Replacement: step 8, image 1 of 1
      • Use the plastic opening tool to lift up the microphone ribbon connector.
      Ask FixBot
    3. Samsung Gear S Microphone Replacement: step 9, image 1 of 1
      • Use the spudger to lift up the white microphone circuit board.
      Ask FixBot
3 other people completed this guide.
Luis Franco
1,076 Reputation
4 Guides authored
USF Tampa, Team 12-1, Blackwell Fall 2015 Member of USF Tampa, Team 12-1, Blackwell Fall 2015
USFT-BLACKWELL-F15S12G1
4 Members
60 Guides authored
3 Guide Comments
ok. thanks a lot but one stupid question where can i buy a new microphone?
amir arya - Reply Share
any chance of posting were to buy a new mic please..
ian stapleton - Reply Share
Past 24 Hours: 3
Past 7 Days: 15
Past 30 Days: 83
All Time: 2,919
