Samsung Gear S Home Button Assembly Replacement
Views: 5.9K
View statistics:
Past 24 Hours:
2
Past 7 Days:
23
Past 30 Days:
98
All Time:
5,901
Comments: 14
12 comments on steps, 2 guide comments.
Go to guide comments
Completed: 2
2 people have marked this guide "completed." Will you be next?
Favorites: 3
3 people have favorited (and subscribed to) this guide. Will you be next?
Time Required: 30 minutes
Difficulty: Moderate
Needs Better Images
Better photos will improve this guide. Help out by taking, editing, or uploading new ones!
Introduction
Go to step 1 ↓
This guide will give step by step instructions on how to replace the home button.
Tools
    1. Samsung Gear S Home Button Assembly Replacement, Display Assembly: step 1, image 1 of 3 Samsung Gear S Home Button Assembly Replacement, Display Assembly: step 1, image 2 of 3 Samsung Gear S Home Button Assembly Replacement, Display Assembly: step 1, image 3 of 3
      • Remove the wrist strap by peeling back the rubber starting from one corner of the watch face. Continue peeling the rubber away from the watch face until the strap is completely off.
      Ask FixBot
    2. Samsung Gear S Home Button Assembly Replacement: step 2, image 1 of 2 Samsung Gear S Home Button Assembly Replacement: step 2, image 2 of 2
      • Starting from an edge, wedge a metal spudger in between the screen and the chrome trim ring and pry, lifting the screen outwards.
      • Some force is needed due to adhesive seal.
      Ask FixBot
    3. Samsung Gear S Home Button Assembly Replacement: step 3, image 1 of 1
      • Use a plastic opening tool to gently pry upwards on the plastic motherboard assembly.
      Ask FixBot
    4. Samsung Gear S Home Button Assembly Replacement: step 4, image 1 of 1
      • Locate the ribbon assembly attaching the display to the motherboard.
      Ask FixBot
    5. Samsung Gear S Home Button Assembly Replacement: step 5, image 1 of 1
      • Use a plastic opening tool to detach the glass screen/ LED Display ribbon connector from the motherboard.
      Ask FixBot
    6. Samsung Gear S Home Button Assembly Replacement: step 6, image 1 of 1
      • Now the watch should be in three separate pieces.
      Ask FixBot
    1. Samsung Gear S Home Button Assembly Replacement, Home Button Assembly: step 7, image 1 of 2 Samsung Gear S Home Button Assembly Replacement, Home Button Assembly: step 7, image 2 of 2
      • Locate the home ribbon connector attached to the wrist side (side that faces the user when wearing it) of the motherboard assembly.
      • Locate the home ribbon assembly attached to the screen side of the motherboard assembly.
      Ask FixBot
    2. Samsung Gear S Home Button Assembly Replacement: step 8, image 1 of 1
      • Use a plastic opening tool to gently pry up on the home ribbon connector.
      Ask FixBot
    3. Samsung Gear S Home Button Assembly Replacement: step 9, image 1 of 1
      • Use the spudger to pry up the home ribbon assembly.
      Ask FixBot
2 other people completed this guide.
Luis Franco
1,076 Reputation
4 Guides authored
USF Tampa, Team 12-1, Blackwell Fall 2015 Member of USF Tampa, Team 12-1, Blackwell Fall 2015
USFT-BLACKWELL-F15S12G1
4 Members
60 Guides authored
2 Guide Comments
where can i buy the home buton?
Hanna Iskandar - Reply Share
I am in search of the SM-R750v Housing Back Cover, any suggestions
Rita Arnold - Reply Share
Past 24 Hours: 2
Past 7 Days: 23
Past 30 Days: 98
All Time: 5,901
