Samsung Gear Live Battery Replacement
Views: 10K
View statistics:
Past 24 Hours:
Past 7 Days:
13
Past 30 Days:
91
All Time:
10,300
Comments: 9
2 comments on steps, 7 guide comments.
Go to guide comments
Completed: 14
14 people have marked this guide "completed." Will you be next?
Favorites: 2
2 people have favorited (and subscribed to) this guide. Will you be next?
Time Required: 2 minutes
Difficulty: Easy
Step Trimmer
This guide has unnecessary steps. Trim them to be more concise!
Introduction
Go to step 1 ↓
The watch contains a small, 300mAh lithium-ion battery. Though these batteries will generally last for years, they do have a limit to the number of times they can be charged. As the battery grows older and is charged repeatedly, it may become less and less able to hold a charge. When this happens, replace the battery.
Tools
    1. Samsung Gear Live Battery Replacement, Lay the watch face-down: step 1, image 1 of 1
      • Lay the watch face-down on a flat, stable surface.
      Ask FixBot
    2. Samsung Gear Live Battery Replacement, Remove the holding pin: step 2, image 1 of 1
      • Press the watchband down against the work surface.
      • Press the tip of a flathead screwdriver against the edge of the spring-loaded holding pin.
      Ask FixBot
    3. Samsung Gear Live Battery Replacement, Remove the watchband: step 3, image 1 of 1
      • With the spring-loaded pin pressed in, the watch band should release easily.
      • Gently pull the band away from the body of the watch.
      • Repeat steps 2 and 3 for the opposite side.
      Ask FixBot
    1. Samsung Gear Live Battery Replacement, Locate the four screws: step 4, image 1 of 1
      • With the watch laying face-down, locate the four screws. They are located on the back of the watch, at the four corners.
      Ask FixBot
    2. Samsung Gear Live Battery Replacement, Remove the 4 screws: step 5, image 1 of 1
      • Using a Torx-T5 screwdriver, remove each of the four 4mm screws and set them aside.
      Ask FixBot
    3. Samsung Gear Live Battery Replacement, Pry off the back of the watch.: step 6, image 1 of 1
      • Gently work the plastic opening tool under the top edge of the watch’s back cover.
      Ask FixBot
    4. Samsung Gear Live Battery Replacement, Lift off the back cover: step 7, image 1 of 2 Samsung Gear Live Battery Replacement, Lift off the back cover: step 7, image 2 of 2
      • With the watch’s back cover pried loose, gently lift it away from the front half of the watch.
      Ask FixBot
    5. Samsung Gear Live Battery Replacement, Set both halves of the watch aside: step 8, image 1 of 1
      • Lay both halves of the watch body assembly face down (with internal components facing up).
      Ask FixBot
    1. Samsung Gear Live Battery Replacement, Locate the battery: step 9, image 1 of 1
      • Locate the battery on the back half of the disassembled watch body. It is rectangular in shape and located just above the window for the heart monitor.
      Ask FixBot
    2. Samsung Gear Live Battery Replacement, Locate the battery contacts: step 10, image 1 of 1
      • Locate the battery’s electrical contacts. They are located next to the heart rate monitor. They roughly form a “+” shape.
      • Using the plastic opening tool, gently pry the contacts away from the plastic channel in which they fit.
      Ask FixBot
    3. Samsung Gear Live Battery Replacement, Pry out the battery: step 11, image 1 of 1
      • Gently work the plastic opening tool under the battery.
      • Using the plastic opening tool, gently pry the battery up.
      • If replacing the battery, please dispose of it properly. Do not throw the battery in the trash. Contact your local municipality for locations which accept lithium-ion batteries for disposal or recycling.
      Ask FixBot
14 other people completed this guide.
Keith Cooper
1,265 Reputation
6 Guides authored
USF Tampa, Team 1-7, Brown Fall 2014 Member of USF Tampa, Team 1-7, Brown Fall 2014
USFT-BROWN-F14S1G7
3 Members
72 Guides authored
7 Guide Comments
Indicate the tools needed.
Dan Brown - Reply Share
Indicate screw measurements to nearest mm.
This is neat and helpful, but where do I find a replacement battery?
joshthehappy - Reply Share
Where can I purchase these batteries?
chad flores - Reply Share
I purchased my battery on eBay.
Jay - Reply Share
Past 24 Hours: 1
Past 7 Days: 13
Past 30 Days: 91
All Time: 10,300
